Prerequisites for installing Workflow Automation
Before installing OnCommand Workflow Automation (WFA), you must ensure that you have the required information and you have completed certain tasks.
Before you install WFA on a system, you must have completed the following tasks:
  • Downloading the WFA installation file from the NetApp Support Site and copying the file to the server on which you want to install WFA
    Note
    You must have valid credentials to log in to the NetApp Support Site. If you do not have valid credentials, you can register on the NetApp Support Site to obtain the credentials.
  • Verifying that the system has access to the following, as applicable:
    • Storage controllers
    • Active IQ Data Center Manager
Note
If your environment requires Secure Shell (SSH) accessibility, you must ensure that SSH is enabled on the target controllers.
  • Verifying that Perl v5.10.1 is installed
Required configuration information
Unit or system Details Purpose
Arrays
  • IP address
  • User name and password
Perform operations on storage systems
Note
Root or admin account credentials are required for storage (arrays).
External repositories such as OnCommand Balance and custom databases
  • IP address
  • User name and password of a read-only user account
Acquire data
You must create the relevant WFA content, such as dictionary entries and cache queries for the external repositories, in order to acquire data from the external repositories.
Mail server
  • IP address
Note
User name and password are required if your mail server requires authentication.
Receive WFA notifications through email
AutoSupport server
  • Mail host
Send AutoSupport messages through SMTP
If you do not have a mail host configured, you can use HTTP or HTTPS to send AutoSupport messages.
Microsoft Active Directory (AD) LDAP server
  • IP address
  • Group name
Authenticate and authorize using AD LDAP or AD LDAPS
SNMP management application
  • IP address
  • Port
Receive WFA SNMP notifications
Syslog server
  • IP address
Send log data
Related information
