Integrate EDA with Perforce
Contributors netapp-mwallis netapp-sineadd
Integrate EDA with the Perforce Helix Visual Client (P4V) so that developers can manage your workspaces using the Perforce CLI. This enables developers to quickly switch between projects and workspaces, saving time during development.
Steps
  1. Download the P4V integration file.
  2. Open P4V and go to Tools > Manage Tools > HTML tabs.
  3. Select Import HTML tabs.
  4. Select the P4V integration XML file and select Import.
  5. Go to View > Workload Factory.
Result
The NetApp Workload Factory for EDA web UI appears as an HTML tab within the P4V client.
