Builders requirements
Ensure that Workload Factory and AWS are set up properly before you use NetApp Workload Factory for Builders. This includes having your AWS log in credentials, a deployed FSx for ONTAP file system, and more.
- Workload factory login and account
You'll need to set up an account with Workload Factory and log in using one of the console experiences.
- AWS credentials and permissions
You need to add AWS credentials to Workload Factory with read/write permissions, which means you'll be using Workload Factory in read/write mode for Builders.
Basic mode and read-only mode permissions are not supported at this time.
- FSx for ONTAP file system
You need a minimum of one FSx for ONTAP file system:
The file system will be used by Builders to store the projects and workspaces that you create.
This FSx for ONTAP file system must use FlexVol volumes. FlexGroup volumes are not supported.
You'll need to know the AWS region, VPC, and subnet where the AWS FSx for ONTAP file system resides.
You'll need at least one volume in the filesystem with the following configuration:
The volume must be configured as an NFS share.
The filesystem must be configured with a link. Learn more about links.
You'll need to consider the tag key/value pairs that you want to apply to the AWS resources that are part of this deployment (optional).
