Analyze error logs in NetApp Workload Factory for Databases
Use the smart error log analyzer to automatically interpret Microsoft SQL Server and Oracle database error logs so that you can quickly identify and resolve issues. The Agentic AI-based analysis requires Amazon Bedrock integration.
About this task
Error log analysis and remediation help maintain the health and performance of SQL Server instances and Oracle databases. Interpreting error logs effectively requires careful analysis and expertise. Manual monitoring, error detection, and root cause analysis are time-intensive and prone to errors. These challenges can delay issue resolution, increased downtime, and operational inefficiencies. The smart error log analyzer addresses these challenges with these key benefits:
Smart grouping: Intelligently consolidates errors by uniqueness, severity, and category, and simplifies the troubleshooting process for faster, more effective resolutions.
AI-driven investigation: Leverages AI to proactively analyze errors, providing clear, actionable insights to accelerate issue identification without requiring deep expertise.
Error enrichment: Enhances error logs with external references, offering contextual clarity to improve understanding and decision-making.
Best-practice remediation: Delivers tailored, remediation recommendations for SQL Server workloads running on FSx for ONTAP, empowering users of all skill levels to resolve issues confidently.
Whenever you use the error log analyzer, you maintain full control over your environment while benefiting from advanced AI analysis.
To use the error log analyzer, you need to activate Amazon Bedrock, select the model Workload Factory uses, create a private endpoint to connect to Amazon Bedrock, add permissions, and create an enterprise license.
If your account admin has turned off AI features, you'll see a message and won't be able to use AI analysis. Contact your administrator or learn about AI administration. |
Data privacy and security
The feature ensures data privacy and security with the following measures:
Log data and aggregations stay within your AWS account, communicated via private VPC endpoint (Amazon Bedrock), ensuring no public internet exposure.
Customer data is not used to train or improve models. Amazon Bedrock processes logs in real time but does not train on your data. Results are stored in your environment for reference only. For more details, refer to the Amazon Bedrock data protection documentation.
Before you begin
To use the error log analyzer, you must meet the following prerequisites:
You must grant view, planning, and analysis permissions in your AWS account to create a new database host in Workload Factory.
Register resources in Workload Factory.
The following prerequisites also must be met. You will be prompted to complete these prerequisites as part of the steps to analyze log errors.
Amazon Bedrock activation
Amazon Bedrock is required so that the AI agent running on the SQL Server or Oracle host from Workload Factory can seamlessly connect with Bedrock and fetch AI-based insights for the identified error logs.
Networking
The Amazon Bedrock VPC endpoint ensures private communication of your SQL Server or Oracle host with Amazon Bedrock APIs and eliminates public internet exposure. Ensure Amazon Bedrock VPC endpoint is associated with the SQL Server or Oracle host's subnet (example: vpce-050cb2f33a1380ffd).
AWS IAM permissions
The following permissions are required for the EC2 instance profile role associated with the SQL Server or Oracle host and for the AWS credentials associated with Workload Factory.
EC2 instance profile role with "bedrock:InvokeModel" permission
This permission enables the EC2 instance on the corresponding SQL Server or Oracle host to invoke Bedrock models for proactive error investigation and remediation guidance. This profile also ensures secure AI access for tailored insights.
AWS credentials associated with Workload Factory: "bedrock:GetFoundationModelAvailability" and "bedrock:ListInferenceProfiles" permissions
These permissions verify model availability and configuration in the region of the SQL Server or Oracle host, and ensure reliable, region-specific performance.
Oracle user permission
The following permission grants read access to extended diagnostic alerts, enabling extraction of error/trace details from logs for AI-powered pattern detection and remediation:
V$DIAG_ALERT_EXT. This permission is required only for Oracle databases.
Analyze error logs
Use the Workload Factory console to analyze SQL Server error logs.
Log in using one of the console experiences.
Select the menu
and then select Databases. -
From the Databases menu, select Inventory.
In the Inventory, select Microsoft SQL Server or Oracle as the database engine type.
From the Instances tab, locate the specific SQL Server instance or Oracle database you want to analyze and then select Investigate errors from the menu.
From the Error investigation tab, complete the following prerequisites as described in the console:
Amazon Bedrock
Networking: Private endpoint for Amazon Bedrock
Permissions for EC2 instance profile role
Credentials associated with Workload Database Management (wlmdb)
When prerequisites are met, select Investigate now to use the error log analyzer to gain insights into your SQL Server error logs.
After the scan, errors are displayed in the console, providing a comprehensive view of the issues detected by the Smart error log analyzer.
Use filters to refine the displayed errors based on criteria such as severity, time frame, and error code, or by infrastructure-oriented tags such as compute, storage, network, and security.
Review the detailed error information, including original error message, AI-based explanation, and suggested remediation steps to resolve the errors.
