Register resources in NetApp Workload Factory for Databases
Register instances for Microsoft SQL Server and databases for Oracle so that you can manage your resources, create databases and sandbox clones, run error log analysis, and optimize configurations in NetApp Workload Factory for Databases.
You can register your resources only if they run on FSx for ONTAP file system storage.
About the task
Registering an instance (SQL Server) or database (Oracle) involves two steps: instance or database authentication and preparation. Authentication is the process of verifying the credentials for the instance or database. Preparation includes installing AWS, NetApp, and PowerShell modules on the instance or database, to meet the minimum requirements for Workload Factory for Databases features like creating a database, creating a sandbox, error log analysis or the well-architected assessment.
Workload Factory supports only Microsoft SQL Server instance and Oracle database registration and management. Depending on the AWS account credentials you select in Workload Factory, PostgreSQL hosts appear in the Inventory. Currently, Workload Factory supports unregistered PostgreSQL instances running only on Amazon Linux operating systems.
Before you begin
You must do the following before you register an instance or database:
Make sure the hosts of the resources that you want to register appear in the inventory. Grant operations and remediation permissions in your AWS account.
Associate a link with the FSx for ONTAP file system that hosts the resources you want to register. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Registering an instance in a private network
To register an instance or database in a private network without external connectivity, make the required endpoints available in the VPC and associate them with the relevant subnets. Allow port 443 in the Security Group for interface endpoints.
S3 Gateway/endpoint -
ssm -
ssmmessages -
fsxIf you use a proxy server for outbound EC2 connections, allow access to these domains for management operations:
.microsoft.com(SQL Server) -
.powershellgallery.com(SQL Server) -
.aws.amazon.com -
.amazonaws.com
Register a Microsoft SQL Server instance
Registering an instance has two steps - instance authentication and preparation. You can register a single instance or multiple instances.
Workload Factory supports registration for Failover Cluster Instance (FCI) and Standalone deployment for SQL Server.
Log in using one of the console experiences.
Select the menu
and then select Databases. -
From the Databases menu, select Inventory.
In the Inventory, select Microsoft SQL Server as the engine type.
Select the Instances tab.
Select to register a single instance or multiple instances.
To Authenticate instances (step 1), do the following and then select Next:
Select to Use the same credentials for all instances or Manage credentials manually.
Authenticate SQL Server and Windows by providing user name and password information.
If instances are authenticated, select Next.
To Prepare (step 2), make sure the instance(s) meets the minimum requirements.
To meet the minimum requirements, the instance must have AWS and NetApp PowerShell modules and PowerShell 7 modules installed, and you must complete the prerequisites for at least one of the capabilities listed under Prerequisite check.
Review the prerequisites in the Prerequisite check view.
You must complete all prerequisites for a single capability like Review well-architected issues and recommendations to register the instance.
Select Setup details for each capability to learn about the capability prerequisites and follow the on-screen instructions to complete any missing prerequisites for a capability.
To enable Workload Factory to review and fix well-architected issues, complete all prerequisites under Review well-architected issues and recommendations and Fix well-architected issues.
After you complete all prerequisites, Register the instance(s).
Instance registration initiates. Select the Job monitoring tab to track progress.
Register an Oracle database
Registering an instance has two steps - database authentication and preparation. You can register a single instance or multiple databases.
Select the menu
In the Inventory, select Oracle as the engine type.
Select the Databases tab.
Select to register a single database or multiple databases.
To Authenticate databases (step 1), do the following and then select Next:
Authenticate Oracle user and Automatic Storage Management (ASM) grid user (if applicable) by providing user name and password information.
If databases are authenticated, select Next.
To Prepare (step 2), make sure the database(s) meets required prerequisites. If all required modules are installed and prerequisites are met, select Next to register the database. Otherwise, follow these steps.
You must complete all prerequisites for a single capability like Review well-architected issues and recommendations to register the database.
To have Workload Factory review and fix well-architected issues for your databases, complete all prerequisites listed under Review well-architected issues and recommendations and Fix well-architected issues capabilities.
After you complete the prerequisites, Register the database(s).
Database registration initiates. Select the Job monitoring tab to track progress.
After registration, you can perform these tasks.
View databases from the inventory
Get a comprehensive well-architected assessment of database configurations
