Create a Microsoft SQL database in NetApp Workload Factory for Databases
Creating a new Microsoft SQL database enables you to manage the resource within NetApp Workload Factory for Databases.
Upon database creation, two new volumes are created in the FSx for ONTAP file system consisting of independent LUNs to host data and log files for the database. The database files in the new database are thin-provisioned and consume only a few MBs of the total size allocated for the new database.
If you want to segregate storage for the database, you can do this by using a virtual mount point. The virtual mount point lets you consolidate databases to a few common drives on the host.
Creating a database in workload factory requires view, planning, and analysis permissions. Alternatively, you can copy or download a partially completed code template to complete the operation outside workload factory. Learn about Workload Factory permissions to decide which mode you'd like to use.
Microsoft SQL Servers using SMB protocol don't support database creation. |
Complete the following prerequisites before you create a new database.
Credentials and permissions: You must have AWS account credentials and operations and remediation permissions to create a new database in Workload Factory.
Alternatively, you can use the Codebox to copy a template so that you can deploy a database outside of workload factory using REST API. Learn more about Codebox automation.
Windows host: You must have enough drive letters available on the Microsoft SQL Server to create new drives for the new database if you use Quick create mode.
Microsoft SQL Server: You must have a managed Microsoft SQL Server in workload factory for Databases to host the new database.
AWS Systems Manager: Ensure the
NT Authority\SYSTEMuser privilege is enabled in the Microsoft SQL host via AWS Systems Manager.
Create a database
You can use Quick create or Advanced create deployment modes to complete this task in Workload Factory.
Log in using one of the console experiences.
Select the menu
and then select Databases. -
From the Databases menu, select Inventory.
In the Inventory, select Microsoft SQL Server as the database engine type.
Select a database server with a managed SQL server instance to create the database in.
Click the action menu of the managed instance and then select Create user database.
On the Create user database page, under Database information, provide the following:
Database name: Enter name for the database.
Collation: Select a collation for the database. The default collation SQL_Latin1_General_CP1_CI_AS" on Microsoft SQL Server is selected.
Under File settings, provide the following:
File settings mode: Select Quick create.
File names & path:
Data file name: Enter the data file name.
Log file name: Enter the log file name.
File sizes: Enter the data size and log size for the database.
Click Create.
Alternatively, if you want to change any of these default settings now, change the File settings mode to Advanced create.
Select the menu
Select Create user database.
Collation: Select the collation for the database. The default collation SQL_Latin1_General_CP1_CI_AS" on Microsoft SQL Server is selected.
File settings mode: Select Advanced create.
File names & path:
Data file: Select a drive letter and enter the data file name.
Optionally, click the box for Virtual mount point.
Log file: Select a drive letter and enter the log file name.
Click Create.
If you created the database host, you can check the job's progress in the Job monitoring tab.
