Explore savings in NetApp Workload Factory for Databases
Explore savings in NetApp Workload Factory for Databases for your database workloads by comparing the costs of using Microsoft SQL Server on Amazon Elastic Block Store (EBS), FSx for Windows File Server, and on-premises storage with FSx for ONTAP storage.
About this task
You can explore savings for your database workloads on EBS, FSx for Windows File Server, and on-premises storage using the Dashboard, Inventory tab, or Explore savings tab. In all cases, you can use the savings calculator to compare various cost components of running Microsoft SQL Server workloads like storage, compute, SQL license, snapshots, and clones for your database workloads on FSx for ONTAP file systems against Elastic Block Store (EBS), FSx for Windows File Server, and on-premises storage.
If Workload Factory finds cost savings on FSx for ONTAP, you can deploy Microsoft SQL over FSx for ONTAP directly from the savings calculator in the Workload Factory console. When you have multiple Microsoft SQL Server instances over Elastic Block Store, FSx for Windows File Server, or on-premises storage, we'll recommend an FSx for ONTAP configuration with a single SQL instance.
Visit the Databases Dashboard in the Workload Factory console to get an overview of potential cost savings for running all of your database workloads on FSx for ONTAP. The Potential savings tile shows your database workloads on EBS and FSx for Windows File Server, potential cost savings, savings percentage, and a bar graph.
You can utilize the savings calculator so you can compare various cost components of running Microsoft SQL Server workloads like storage, compute, SQL license, snapshots, and clones for your database workloads on FSx for ONTAP file systems against Elastic Block Store (EBS), FSx for Windows File Server, and on-premises storage. FSx for ONTAP file systems may be the most cost-effective option for your database workloads.
The calculator displays whether the storage for the database workloads on these Microsoft SQL Servers would cost less if you used an FSx for ONTAP file system. Learn how to use the calculator.
SQL Server deployment analysis
The calculator checks your SQL Server deployment to make sure the resources and features used match the SQL Server edition. Here are the key factors and conditions the calculator checks before recommending a downgrade to Standard Edition:
The calculator evaluates the deployment model and whether Enterprise edition is required.
The calculator assesses the conditions of the following license-dependent allocated resources:
Target Instance vCPUs: The instance has 48 or fewer virtual CPUs.
Memory Allocation: The instance has 128GB or less of memory.
The calculator verifies if any of the following Enterprise features are in use:
Database-level Enterprise features
Online index operations
Resource Governor
Peer-to-peer or Oracle replication
R/Python extensions
Memory-optimized TempDB
If the assessed SQL Server instance doesn't utilize any of the above Enterprise features and meets the resource constraints, the calculator will recommend downgrading the license to Standard Edition. The calculator helps you optimize SQL Server licensing costs without reducing performance or functionality.
Calculator options
Two calculator options are available for making the cost comparison between your systems and FSx for ONTAP — customization and detection.
Explore savings via customization: You provide the configuration settings for Microsoft SQL server on Amazon EC2 with EBS or FSx for Windows File Server including the region, deployment model, SQL server edition, monthly data change rate, snapshot frequency, and more.
Explore savings for detected hosts: Workload Factory links to your existing Microsoft SQL servers and pulls in the details to the calculator for automatic comparison. You'll need to grant view, planning, and analysis permissions to use this calculator option. You can change the use case, but all other details are automatically determined in the calculation.
Additionally, you can add AWS credentials to improve the accuracy of the calculator analysis. Select Calculate savings based on existing resources. You'll be redirected to the Add credentials page. After you add credentials, select the existing resources to compare with FSx for ONTAP, and select Explore savings.
Customize the fields in the calculator to get the most accurate savings estimate.
Customize savings for Microsoft SQL Server hosts
Follow the steps under the tab for your storage type.
Log in using one of the console experiences.
Select the menu
and then select Databases. -
From Databases, select Explore savings then Microsoft SQL Server on EBS.
In the Savings calculator, provide the following details:
Region: Select a region from the dropdown menu.
Deployment model: Select a deployment model from the dropdown menu.
SQL server edition: Select the SQL server edition from the dropdown menu.
Monthly data change rate (%): Enter the percentage that clone and snapshot data changes on average per month.
Snapshot frequency: Select a snapshot frequency from the dropdown menu.
Number of cloned copies: Enter the number of cloned copies in the EBS configuration.
Monthly SQL BYOL cost ($): Optionally, enter the monthly SQL BYOL cost in dollars.
Under EC2 specifications, provide the following:
Machine description: Optionally, enter a name to describe the machine.
Instance type: Select the EC2 instance type from the dropdown menu.
Under Volume types, provide the following details for at least one volume type. IOPS and throughput apply to certain disk type volumes.
Number of volumes
Storage amount per volume (GiB)
Provisioned IOPS per volume
Throughput MB/s
If you selected the Always On availability deployment model, provide details for Secondary EC2 specifications and Volume types.
Select the menu
From Databases, select Explore savings then Microsoft SQL Server on FSx for Windows.
Under FSx for Windows File Server settings, provide the following:
Deployment type: Select the deployment type from the dropdown menu.
Storage type: SSD storage is the supported storage type.
Total storage capacity: Enter the storage capacity and select the capacity unit for the configuration.
Provisioned SSD IOPS: Enter the provisioned SSD IOPS for the configuration.
Throughput (MB/s): Enter throughput in MB/s.
Under EC2 specifications, select the Instance type from the dropdown menu.
After you provide details for your database host configuration, review the calculations and recommendations provided on the page.
Additionally, scroll down to the bottom of the page to view the report by selecting one of the following:
Export PDF
Send by email
View the calculations
To switch to FSx for ONTAP, follow the instructions to deploy Microsoft SQL Server on AWS EC2 using FSx for ONTAP file systems.
Customize savings for Oracle hosts on EBS
Customize the fields in the calculator to get the most accurate savings estimate for your Oracle hosts running on Amazon Elastic Block Store (EBS).
Select the menu
From Databases, select Explore savings then Oracle on EBS.
Oracle edition: Select the Oracle edition from the dropdown menu.
Monthly Oracle BYOL cost ($): Optionally, enter the monthly Oracle BYOL cost in dollars.
Number of volumes
Throughput MB/s
Export PDF
Send by email
Workload Factory enters the detected host characteristics so that you can explore savings automatically.
Complete the following prerequisites before you begin:
Grant view, planning, and analysis permissions in your AWS account to detect Elastic Block Store (EBS) and FSx for Windows systems under the Explore savings tab and to show the savings calculation in the savings calculator.
To get instance type recommendations and improve cost accuracy, do the following:
Grant Amazon CloudWatch and AWS Compute Optimizer permissions.
Sign in to the AWS Management Console and open the IAM service.
Edit the policy for the IAM role. Copy and add the following Amazon CloudWatch and AWS Compute Optimizer permissions.
{ "Version": "2012-10-17", "Statement": [ { "Effect": "Allow", "Action": "compute-optimizer:GetEnrollmentStatus", "Resource": "*" }, { "Effect": "Allow", "Action": "compute-optimizer:PutRecommendationPreferences", "Resource": "*" }, { "Effect": "Allow", "Action": "compute-optimizer:GetEffectiveRecommendationPreferences", "Resource": "*" }, { "Effect": "Allow", "Action": "compute-optimizer:GetEC2InstanceRecommendations", "Resource": "*" }, { "Effect": "Allow", "Action": "autoscaling:DescribeAutoScalingGroups", "Resource": "*" }, { "Effect": "Allow", "Action": "autoscaling:DescribeAutoScalingInstances", "Resource": "*" } ] }
Opt the billable AWS account in to AWS Compute Optimizer.
Explore savings for detected Microsoft SQL Server hosts
Select the menu
From the Databases menu, select Explore savings.
In Explore savings, select the SQL Server on Elastic Block Store (EBS) tab.
If Workload Factory detects EBS hosts, it redirects you to the Explore savings tab. If it doesn't detect EBS hosts, it redirects you to the calculator to explore savings via customization.
From Explore savings, select one or more database hosts running on EBS and then select Explore savings.
If required, authenticate the database host with SQL Server credentials, Windows credentials, or by adding missing SQL Server permissions.
If the Explore savings page doesn't load data after successful authentication, select the Inventory tab to reload the data, and then select the Explore savings tab again.
In the Savings calculator, you can give the following details on clones and snapshots in your EBS storage for a more accurate cost savings estimate.
Snapshot frequency: Select a snapshot frequency from the menu.
Clone refresh frequency: Select the frequency that clones refresh from the menu.
Monthly change rate: Enter the percentage that clone and snapshot data changes on average per month.
Add hosts: Optionally, select up to five detected EBS hosts to include in the savings calculation.
Workload Factory consolidates multiple SQL Server hosts into a single FSx for ONTAP configuration recommendation to optimize cost savings unless the selected EBS hosts exceed throughput, capacity, or IOPS limits for a single FSx for ONTAP file system.
Select the menu
In Explore savings, select the SQL Server on FSx for Windows tab.
If Workload Factory detects FSx for Windows hosts, it redirects you to the Explore savings tab. If it doesn't detect FSx for Windows hosts, it redirects you to the calculator to explore savings via customization.
In the Explore savings tab, select Explore savings of the database host using FSx for Windows File Server storage.
In the Savings calculator, optionally, provide the following details on clones (shadow copies) and snapshots in your FSx for Windows storage for a more accurate cost savings estimate.
If Workload Factory detects FSx for Windows shadow copies, it sets the default value to Daily. If it doesn't detect shadow copies, it sets the default value to No snapshot frequency.
Number of cloned copies: Enter the number of cloned copies in the FSx for Windows configuration.
Select the menu
In Explore savings, select engine type Microsoft SQL Server.
Next, select the SQL Server on-premises tab.
From the SQL Server on-premises tab, select Assessment script > Assessment script information and review the information provided.
Select Download assessment script.
The script is a data collection tool based on PowerShell. It gathers and then uploads SQL Server configuration and performance data to Workload Factory. The migration advisor assesses the data and plans FSx for ONTAP deployment for your SQL Server environment.
Run the script on the SQL Server host with a user that has sufficient privileges.
Select Upload script results in the SQL Server on-premises tab in Workload Factory.
From the SQL Server on-premises tab, select up to five database hosts and then select Explore savings to run a cost analysis of the SQL Server on-premises host(s) against FSx for ONTAP.
In the Savings calculator, select the region for the on-premises host.
Optionally, provide the following details on clones (shadow copies) and snapshots in your on-premises database environment for a more accurate cost savings estimate.
Number of cloned copies: Enter the number of cloned copies in the on-premises configuration.
For more accurate results, update Compute information and Storage and performance details.
Workload Factory consolidates multiple SQL Server on-premises hosts into a single FSx for ONTAP configuration recommendation to optimize cost savings unless the selected on-premises hosts exceed throughput, capacity, or IOPS limits for a single FSx for ONTAP file system.
After you've explored savings for a Microsoft SQL server on-premises host, you have the option to remove the on-premises host record from Workload Factory. Select the action menu of the Microsoft SQL Server on-premises host and then select Delete.
Export PDF
Send by email
Explore savings for detected Oracle hosts
Select the menu
In Explore savings, select the Oracle on Elastic Block Store (EBS) tab.
If required, authenticate the database host with Oracle credentials, or by adding missing Oracle permissions.
Workload Factory consolidates multiple Oracle hosts into a single FSx for ONTAP configuration recommendation to optimize cost savings unless the selected EBS hosts exceed throughput, capacity, or IOPS limits for a single FSx for ONTAP file system.
Select the menu
Next, select the Oracle Server on-premises tab.
From the Oracle Server on-premises tab, select Assessment script > Assessment script information and review the information provided.
The script is a data collection tool based on PowerShell. It gathers Oracle Server configuration and performance data.
Run the script on the Oracle host with a user that has sufficient privileges.
Select Upload script results and then upload the script output file to the Workload Factory console. The migration advisor assesses the data and plans FSx for ONTAP deployment for your Oracle Server environment.
From the Oracle Server on-premises tab, select the on-premises Oracle Server and then select Explore savings to run a cost analysis against FSx for ONTAP.
Workload Factory consolidates multiple Oracle on-premises databases into a single FSx for ONTAP configuration recommendation to optimize cost savings unless the selected on-premises databases exceed throughput, capacity, or IOPS limits for a single FSx for ONTAP file system.
After you've explored savings for an Oracle on-premises host, you have the option to remove the on-premises host record from Workload Factory. Select the action menu of the Oracle on-premises host and then select Delete.
Export PDF
Send by email
Deploy Microsoft SQL Server on AWS EC2 using FSx for ONTAP
If you'd like to switch to FSx for ONTAP to realize cost savings, click Create to create the recommended configuration(s) directly from the Create new Microsoft SQL server wizard or click Save to save the recommended configuration(s) for later.
Workload Factory doesn't support saving or creating multiple FSx for ONTAP file systems. |
With database host creation permissions, you can deploy the new Microsoft SQL server on AWS EC2 using FSx for ONTAP directly from Workload Factory. You can also copy the content from the Codebox window and deploy the recommended configuration using one of the Codebox methods.
Without permissions, you can copy the content from the Codebox window and deploy the recommended configuration using one of the Codebox methods.
