Refresh a database clone in NetApp Workload Factory for Databases
Contributors netapp-rlithman
Refresh a database (sandbox) clone in NetApp Workload Factory for Databases so that it is equivalent to the source database at the current moment or a previous point in time.
About this task
Refreshing a clone updates the clone either to the source database at the current moment or to a snapshot of the source database taken at a previous point in time. Any changes made to the sandbox clone will be deleted.
Before you begin
A refresh is only possible when the source database is active.
To refresh a database clone from a snapshot, the source database must have at least one snapshot for the operation.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Databases.
  3. From the Databases menu, select Sandboxes.
  4. In Sandboxes, select the action menu of the sandbox clone you want to refresh.
  5. Select Refresh.
  6. In the Refresh dialog, select one of the following options:
    1. Refresh to current time
    2. Refresh to point in time
      For this option, select the database snapshot from the dropdown menu to refresh to.
  7. Click Refresh.
