Connect a sandbox clone to CI/CD in NetApp Workload Factory for Databases
Contributors netapp-rlithman
Connect a sandbox clone to a continuous integration and continuous delivery (CI/CD) pipeline with REST API code to improve software delivery via automation in NetApp Workload Factory for Databases.
About this task
To deliver a new version of software automatically to your database clone, you should connect to a CI/CD pipeline. Use the REST API code provided from this operation to make the connection.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Databases.
  3. From the Databases menu, select Sandboxes.
  4. In Sandboxes, select the actions menu of the sandbox clone to connect to CI/CD tools.
  5. Select Connect to CI/CD tools.
  6. In the CI/CD dialog, copy or download the REST API code needed to connect to CI/CD tools.
  7. Click Close.
