Amazon FSx for NetApp ONTAP
Access your FSx for ONTAP file system data
Contributors netapp-rlithman
You can access your FSx for ONTAP file systems from on-premises by mounting volumes for NAS clients and mounting iSCSI LUNs for SAN clients.
Accessing data in Amazon FSx for NetApp ONTAP documentation provides information about how to access data.
You can also get the mount point for volumes in NetApp Workload Factory.
Get mount point for volumes in NetApp Workload Factory
Get the mount point for a volume to mount the volume as a CIFS share or on an NFS client.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select Volumes explorer.
  4. Select the actions menu for the volume, then Basic actions, and then View mount command.
  5. In the Mount command dialog, select Copy to copy the command for either the NFS mount point or CIFS share. You'll enter the copied command in your terminal.
  6. Select Close.
