Amazon FSx for NetApp ONTAP
Apply ONTAP-level tags to block devices in NetApp Workload Factory
Contributors netapp-rlithman
Use the native EC2 user data script from NetApp Workload Factory to automatically create and tag block devices during AWS EC2 instance deployment. Add the EC2 user data script to the launch instance wizard template when deploying an EC2 instance from the AWS EC2 Console. After deployment, Workload Factory uses the metadata collected from the script to apply ONTAP-level tags to your block devices. These tags help you see which host is consuming each block device so that you can quickly correlate usage to the responsible host when troubleshooting or auditing.
About this task
The EC2 user data script creates block devices and applies ONTAP-level EC2 tags to the block devices during EC2 instance deployment.
The EC2 tag that is applied to the block device contains the EC2 name, the EC2 ID, and the mount path for the block device(s) within the EC2 instance.
Steps
  1. Follow the Amazon Elastic Compute Cloud instructions for launching an EC2 instance using the launch instance wizard in the AWS EC2 Console.
  2. Add the EC2 user data script to the launch instance wizard template to automatically create and tag block devices.
    Go to our GitHub repository FSx-ONTAP-sample-scripts to get the EC2 user data script.
  3. Launch the instance.
    The EC2 user data script automatically applies ONTAP-level tags to new block storage devices hosted on the EC2 instance.
  4. For existing EC2 instances, user data scripts take effect only after a reboot.
Result
EC2 tags appear in the block device table within the associated FSx for ONTAP file system.
