Change the CIFS share for a volume
Contributors netapp-rlithman
Changing a volume's CIFS share involves determining the users and groups to give access to and the type of access to give them.
Before you begin
Determine the users or groups to give access to and the type of access to give them.
Steps
  1. Log in to the Workload Factory console
  2. In Storage, select Go to storage inventory.
  3. In the FSx for ONTAP tab, select the three dots menu of the file system with the volume to update and then select Manage.
  4. From the file system overview, select the Volumes tab.
  5. From the Volumes tab, click the three dots menu of the volume to change the SMB share for.
  6. Select Advanced actions, then Edit CIFS share.
  7. On the Edit CIFS share page, provide the following:
    1. Users or groups: Enter valid users and groups. Separate each entry by a semi-colon “;”.
    2. Permissions: Select Full control, Read/Write, Read, or No access.
  8. Click Apply.
