Change the NFS export policy for a volume
Change the NFS export policy for a volume that uses NFSv3 or NFSv4.1 protocol types.
Changing a volume's export policy involves adding export policy rules which detail client specifications, access control, super user access, and NFS version. You can add more than one export policy and prioritize them.
Determine the client specifications for the export policy rules. Valid values for the client specification are as follows:
IP addresses
IP addresses with subnet masks
IP addresses with a network mask
A netgroup name preceded by the “@” character
A domain name preceded by a period “.”
Host names
Log in to the Workload Factory console
In Storage, select Go to storage inventory.
In the FSx for ONTAP tab, select the three dots menu of the file system with the volume to update and then select Manage.
From the file system overview, select the Volumes tab.
From the Volumes tab, click the three dots menu for the volume to change the NFS export policy for.
Select Advanced actions, then Edit NFS export policy.
On the Edit NFS export policy page, provide the following:
Access control: Select Custom export policy or Existing export policy.
Alternatively, you can select No access to the volume.
Export policy name: Optionally, enter a name for the export policy.
Add export policy rule: Provide the following details and rank the policies starting with #1 as the priority rule:
Client specification: Separate multiple values with commas.
Access control: Select Read/Write, Read only, or No access from the dropdown menu.
Super user access: Select Yes or No.
NFS version: Select All, NFSv3, or NFSv4.
Click Apply.
