Change the replication schedule of a source volume
Change the replication schedule of the source volume in a replication relationship in NetApp Workload Factory.
Choose how frequently snapshots from the source volume are transferred to the replicated volume to match your required point objectives (RPOs).
When an on-premises ONTAP cluster is the target for the replication relationship, changing the replication schedule isn't supported.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
From the file system overview, select the Replication relationships tab.
In the Replication relationships tab, select the actionsenu of the replication relationship schedule to change.
Select Edit replication interval.
In the Edit replication interval dialog, select the frequency of snapshot transfer from the source volume. You may select between the following frequencies:
Every 5 minutes
Hourly
Every 8 hours
Daily
Weekly
Select Apply.
