Amazon FSx for NetApp ONTAP
Change the tiering policy of a volume in NetApp Workload Factory
Contributors netapp-rlithman
In NetApp Workload Factory, you can change the tiering policy to automatically re-allocate data from the high-performance primary storage tier to the secondary capacity pool storage tier.
About this task
You can change the tiering policy of a volume at any time. The tiering policy is defined per volume.
Deciding where your data is stored has implications for your cost savings.
FSx for ONTAP has two tiers for storing volume data:
  • SSD storage tier: This primary storage tier is for the data you access most frequently, also known as hot data. Storing data in the primary storage tier is more expensive than in the secondary storage tier.
  • Capacity pool storage tier: This secondary storage tier is for archived data or infrequently accessed data, also known as cold data.
Refer to Managing storage capacity in AWS for FSx for NetApp ONTAP documentation for more information about storage tiers.
Before you begin
Review the available tiering policies before you change the tiering policy.
  • Balanced (Auto): default tiering policy when creating a volume using the user interface. Keeps frequently accessed data in the SSD storage tier and tiers infrequently accessed data and snapshots to the capacity pool storage tier after the cooling period ends. Recommended for general primary workloads.
  • Cost-optimized (All): Tiers all snapshots and data to the capacity pool storage tier. Recommended for secondary targets.
  • Performance-optimized (Snapshots only): Tiers only snapshot data to the capacity pool storage tier. Recommended for low-latency workloads such as mission-critical databases.
  • None: Keeps volume data in the SSD storage tier, preventing it from being moved to the capacity pool storage tier.
Some tiering policies have an associated minimum cooling period that sets the time, or cooling days, that user data in a volume must remain inactive for the data to be considered "cold" and moved to the capacity pool storage tier. The cooling period starts when data is written to the disk.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select Volumes explorer.
  4. Select the actions menu of the volume to change the tiering policy for.
  5. Select Advanced actions, then Change tiering policy.
  6. On the Change tiering policy page, select to copy the tiering policy of the source volume or select one of the following tiering policies:
    • Balanced (Auto): Enter the number of cooling days.
    • Performance-optimized (Snapshots only): Enter the number of cooling days.
    • None
  7. Select Apply.
