Configuration analysis for FSx for ONTAP file systems
NetApp Workload Factory analyzes Amazon FSx for NetApp ONTAP file system configurations regularly to determine if there are any configuration issues. When issues are found, Workload Factory shows you what the issues are and explains what to change so your file system storage achieves peak performance, cost efficiency, and compliance with best practices.
Key capabilities include:
Daily configuration analysis
Automatic best practice validations
Proactive observability
Insights to action
AWS Well-Architected Framework advisor
How it works
Workload Factory analyzes your workloads on supported cloud storage deployments every day. The analysis provides well-architected status, insights, and recommendations.
After the daily analysis completes, configurations appear as "optimized" or "not optimized" in the Well-architected dashboard for the deployment. You'll find configuration issues organized by category, along with recommendations. Workload Factory can automatically fix some issues; for issues that require manual intervention, Workload Factory provides detailed instructions to help you implement the recommended changes.
You can dismiss the analysis of configurations that do not apply to your environments. This avoids unnecessary alerts and inaccurate optimization results.
You can also create custom rules in plain language to validate your environments against your organization's standards and NetApp best practices. You can start a rule from a supported well-architected configuration, or write your own prompt. Test rules with a dry run, then schedule them to run across your environments. Learn more about custom rules.
Why it matters
Workload Factory applies best practices to large storage, database, and VMware environments by combining ongoing assessment with recommendation insights and remediation. Automated fixes reduce human error, ensure uniform management, and preserve performance and reliability across your workload infrastructures.
Analysis requirements
For a complete file system analysis, you must do the following:
Associate a link. Link connectivity lets Workload Factory analyze all file system configurations like data protection and performance.
Grant view, planning, and analysis permissions in your AWS account.
Best practices and recommendations for storage workloads
The well-architected dashboard assesses storage configurations against ONTAP best practices and the AWS Well-Architected Framework. The assessment also recommends improvements and fixes.
The well-architected analysis categorizes configurations in the following pillars of the framework: reliability, security, operational excellence, cost optimization, and performance efficiency.
Currently, Workload Factory doesn't provide workload-specific recommendations for all configurations. Tailor your configurations to specific workload needs. |
Reliability
Reliability ensures that workloads perform their intended functions correctly and consistently, even when there are disruptions.
Volume backups
Backing up your volumes helps support data retention and compliance needs. Use volume backups to set up automated backups and retention for your data.
Snapshot policy
Schedule local snapshots for efficient backup and quick restores. Snapshots are instant, point-in-time images of your volumes. This recommendation doesn't apply to database environments.
Application-consistent snapshots
For database environments, use application-consistent snapshots with NetApp SnapCenter to take accurate, reliable snapshots of your volume data at a specific moment in time. This helps keep your applications running smoothly and your data protected. SnapCenter makes backups easier and helps you restore data quickly and correctly, reducing downtime and protecting your most important workloads.
Cross-region replication
Cross-region replication ensures that your data is replicated to another AWS region, providing enhanced data durability and availability. Set up cross-region replication to support disaster recovery and compliance.
SSD capacity headroom
The SSD storage tier capacity should not exceed 80% utilization. This might impact data reads and writes to your capacity pool storage tier and impact the throughput capacity of your file system. When capacity runs out, data volumes become read-only. Services trying to write new data also fail.
Replication policy labels
The snapshot policy labels of the source volume and the replication policy labels must match to ensure data reliability.
File object capacity
Raise the file capacity threshold to avoid reaching the volume capacity limit. Low file capacity (inodes) prevents writing additional data to the volume. Workload Factory recommends maintaining file capacity utilization below 80% to allow new file creation.
Connect host to failover node
Workload Factory recommends connecting hosts to the failover node to maintain connectivity and avoid disruptions during failovers.
DNS and LDAP server redundancy
Configure at least two DNS servers on storage VMs that use DNS, and at least two LDAP servers on storage VMs that use LDAP. A single DNS server can break name resolution and domain authentication. A single LDAP server can cause UNIX identity lookups to fail and block NFS and multiprotocol access.
Database snapshot policy
Set the snapshot policy to "None" for SAP HANA, MySQL, and PostgreSQL volumes to lower storage costs and improve performance for active database data.
Security
Security emphasizes protecting data, systems, and assets through risk assessments and mitigation strategies.
Ransomware protection (ARP/AI)
Enable NetApp Autonomous Ransomware Protection with AI (ARP/AI) on volumes to protect your volumes from ransomware threats. Workload Factory recommends enabling ARP/AI for all volumes.
Unauthorized iSCSI volume access
Volumes serving application data using iSCSI should not allow NAS access at the same time. Workload Factory recommends restricting iSCSI volumes from using any other protocol.
ARP/AI multi-device detection gap
ARP/AI provides full protection coverage when a volume has only one block device attached to it. If a volume has multiple block devices attached, Workload Factory moves the block devices to new volumes so that each volume has only one block device.
Disable
showmounton the application storage VMDisable
showmounton the application storage VM to prevent clients from listing exports they can't access.
Operational excellence
Operational excellence focuses on delivering the most optimal architecture and business value.
Automatic capacity management
Enable automatic capacity management to regularly ensure that the SSD tier doesn't exceed the threshold.
Volume capacity headroom
Keep volume utilization below 80% to prevent potential application read/write impacts. You can increase capacity manually or with volume autogrow.
FlexCache write mode
For optimal performance, set the cache relationship write mode to best suit your workload. Write-around mode provides better performance for read-heavy workloads with small files, whereas write-back mode provides better performance for write-heavy workloads with large files.
FlexCache replica size
Enable volume autosize and scrubbing on cache volumes to maintain optimal size and focus the cache on hot data for peak efficiency.
Host-visible capacity reporting
Enable host-visible capacity reporting to provide better visibility into storage usage at the volume level.
Operating System (OS) type
Confirm that the ONTAP LUN operating system (OS) type value matches the operating system partitioning scheme to achieve I/O alignment. Incorrect configuration might reduce performance.
Block device space management
Configure block device space settings for LUNs used by database host instances to prevent write failures and improve space efficiency on FSx for ONTAP. This configuration applies to the recommended combination of settings for thin-provisioned volumes: space reservation, space allocation, and fractional reserve.
Thin provisioning
Configure thin provisioning for FSx for ONTAP volumes hosting database instances. This approach allows more logical data to be stored than physically available.
Configuration for AWS MGN
Configure FSx for ONTAP file systems with the required AWS Transform MGN (MGN) connectivity and API authentication settings before using them with AWS MGN.
Match igroup OS to host
Match the initiator group (igroup) OS type to the host operating system to keep I/O aligned and prevent performance issues.
Cost optimization
Cost optimization helps you get the most value for your business while keeping costs low.
Cold data tiering
Enable cold data tiering to reduce SSD storage tier utilization. Apply a tiering policy to every volume focused on general data storage. For database volumes other than SAP HANA primary volumes, enable cold data tiering where appropriate. FSx for ONTAP continuously scans the data for cold data and moves it to the capacity pool tier without disruption.
Storage efficiencies
Enable storage efficiencies — compaction, compression, and deduplication — to optimize storage utilization and reduce the SSD tier cost.
Backup expiration
Delete any manually created backups for volumes that were deleted, and any backups older than two weeks. These backups don't expire automatically, can increase costs, and add complexity if you no longer need them for SLA or recovery.
Snapshot expiration
Delete old or manually created snapshots you no longer need. Removing them can lower costs and reduce clutter, especially if they aren't required for your SLA or recovery needs.
Inactive block devices
After a block device isn't used for seven days, archive block device data to the capacity pool tier or delete the unused block device to reduce costs.
Overprovisioned SSD capacity
Excess SSD capacity adds unnecessary cost. Reduce the SSD tier while maintaining a 20% free space buffer. The operation might take hours to days, and no other file system operations are supported during that time.
Inactive NAS volumes
After a NAS volume isn't used for 31 days, archive the data to the capacity pool tier or delete the unused NAS volume to reduce costs.
Clone cleanup
Delete any volume clones older than 30 days to optimize storage usage and reduce costs.
Performance efficiency
Performance efficiency helps you ensure that your storage resources are used effectively and that workloads perform optimally.
FlexGroup volumes rebalance
Rebalance your FlexGroup volumes to improve efficiency. After scaling out, capacity and workload activity can become uneven across the volume.
FlexVol volumes rebalance
Rebalance your FlexVol volumes to improve efficiency. After scaling out, capacity and workload activity can become uneven across the volume.
Volume space management
Enable coordinated volume space management to reduce the risk of a volume running out of space. Without it, unexpected data or snapshot growth can fill a volume, causing write failures and application impact.
