Implement well-architected FSx for ONTAP file system configurations
Use Workload Factory to implement best practices for your FSx for ONTAP file systems. You can easily review the well-architected status, learn about issues with your configurations, and fix issues to improve the architecture of any systems that aren't optimized for reliability, security, efficiency, performance, and cost.
About this task
Workload Factory analyzes Amazon FSx for NetApp ONTAP file system deployment configurations daily.
Because requirements for storage configurations vary, you can dismiss the analysis of specific configurations that don't apply to your storage environment.
Link connectivity allows Workload Factory to scan for issues with performance, data protection, and configurations. Connect to an FSx for ONTAP file system using a link for the most comprehensive analysis of your file system resources.
Workload Factory analyzes the well-architected status of the following configurations for FSx for ONTAP file systems:
Reliability: volume backups, snapshot policy, cross-region replication, SSD capacity headroom, replication policy labels, and file object capacity
Security: Ransomware Protection (ARP/AI) and unauthorized iSCSI volume access
Operational excellence: automatic capacity management, volume file capacity headroom, FlexCache write mode, FlexCache replica size, host-visible capacity reporting, OS type, block device space management, and thin provisioning
Cost optimization: cold data tiering, storage efficiencies, backup expiration, snapshot expiration, inactive block devices, overprovisioned SSD capacity, and inactive NAS volumes
Performance efficiency: FlexGroup volumes rebalance and FlexVol volumes rebalance
Before you begin
You must grant operations and remediation permissions in your AWS account.
Fix a configuration issue
You can fix configuration issues for an FSx for ONTAP file system or for selected volumes in a file system. You can select one or more configurations to fix.
Fix operations can cause instance downtimes or service interruptions. Review each recommendation carefully before fixing a configuration issue.
Log in using one of the console experiences.
Select the menu
and then select Well-architected. -
Select View and fix for any configuration. Review the recommendation carefully.
The recommendation explains best practices and potential pitfalls of unoptimized configurations.
Select resources and then Fix.
Some fix operations are only available for specific operations and not always for more than one resource. For example, you might be able to fix the configuration for a single volume but not for multiple volumes.
Review the action items to learn about consequences of this fix such as instance downtimes or service interruptions.
Select Fix if you want Workload Factory to apply the recommended changes.
The fix process starts. Select the account settings menu and then select Tracker to view the status of the operation.
Customize a configuration as a custom rule
Match an architecture check to your organization's standard so the original recommendation remains available.
If Customize as rule is available, you can create a custom rule from that configuration. The prompt is prefilled from the configuration and won't be submitted until you send it.
Select the menu
Select the configuration that you want to adjust.
If Customize as rule is available, select it.
Custom rules opens with a prompt based on your configuration. The prompt is not submitted. Edit the prompt to use a different resource, threshold, or check.
Complete the steps to review the prompt, validate the rule, and save or schedule it. The rule stays in draft until you schedule it.
The original configuration stays in the well-architected dashboard and is not removed. The rule description explains that the rule is based on this configuration. A custom rule only reads your environment. To apply the recommendation, update the configuration in the dashboard.
Dismiss a configuration analysis
Stop a configuration analysis indefinitely for one or more resources. You can restart the analysis when needed.
Dismiss to stop configuration analysis for one or more FSx for ONTAP file systems or volumes. You can restart the analysis anytime.
Select the menu
Under Configurations, identify the configuration that doesn't apply to your environment.
Select
and then select Dismiss. -
In the Dismiss configuration dialog, select Dismiss to stop the analysis for the configuration.
Select the menu
In the FSx for ONTAP well-architected dashboard, under Configurations, select the configuration that doesn't apply to your environment.
On the configuration page, select the resource(s) to dismiss from the configuration analysis.
For one resource: select
For multiple resources: select the resources and then select Dismiss next to Bulk action.
In the Dismiss resources dialog, select Dismiss to stop the analysis.
Workload Factory stops the configuration analysis for selected configurations.
Reactivate a dismissed configuration analysis
Reactivate a dismissed configuration analysis at any time. You can select one or more configurations or resources to reactivate.
Select the menu
Select Dismissed configurations.
Identify the configuration(s) you want to reactivate and select Reactivate.
Select the menu
On the configuration page, select Dismissed configurations.
Select the resource(s) to reactivate.
and then select Reactivate. -
For multiple resources: select the resources and then select Reactivate next to Bulk action.
Workload Factory reactivates the configuration analysis and runs a new analysis every day.
