Delete a file system in NetApp Workload Factory
To delete a file system in NetApp Workload Factory, you must first delete any volumes, storage VMs, or replication relationships associated with the file system.
Steps
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the FSx for ONTAP file system you want to delete.
Select Manage.
In the Overview tab, select the actions menu.
Select Delete.
In the Delete FSx for ONTAP file system dialog, enter the name of the FSx for ONTAP file system to delete.
Select Delete to confirm.
