Amazon FSx for NetApp ONTAP
Delete a storage VM in NetApp Workload Factory
Contributors netapp-rlithman
Delete a storage VM (SVM) that you no longer require from an FSx for ONTAP file system configuration.
Before you begin
Review the following before you delete a storage VM:
  • Make sure that no applications are accessing the data in the SVM.
  • Delete all non-root volumes attached to the SVM.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
  5. In the file system overview under Storage VMs, select Manage.
  6. On the Manage storage VMs screen, select the actions menu of the storage VM to delete.
  7. Select Delete storage VM.
  8. In the Delete storage VM dialog, type “delete” to delete the storage VM.
  9. Select Delete to confirm.
