Edit storage VM tags
Contributors netapp-rlithman
Tags can help you categorize your resources. You can add, edit, and remove tags for a storage VM at any time.
Steps
  1. Log in to the Workload Factory console
  2. In Storage, select Go to storage inventory.
  3. In the FSx for ONTAP tab, select the three dots menu of the file system with the storage VM to update and then select Manage.
  4. From the file system overview, select the Storage VMs tab.
  5. From the Storage VMs tab, select the three dots menu of the storage VM to edit tags for.
  6. Select Edit storage VM tags.
  7. On the Edit storage VM tags page, add, edit, or remove tags.
    The maximum number of tags you can apply to a storage VM is 50.
  8. Click Apply.
