Edit volume tags
Contributors netapp-rlithman
Tags can help you categorize your resources. You can add, edit, and remove volume tags at any time for FSx for ONTAP volumes.
Steps
  1. Log in to the Workload Factory console
  2. In Storage, select Go to storage inventory.
  3. In the FSx for ONTAP tab, select the three dots menu of the file system with the volume to update and then select Manage.
  4. From the file system overview, select the Volumes tab.
  5. From the Volumes tab, click the three dots menu for the volume to modify tags for.
  6. Select Basic actions then Edit volume tags.
  7. On the Edit volume tags page, add, edit, or remove tags.
    The maximum number of tags you can apply to a volume is 50.
  8. Click Apply.
