Known limitations of FSx for ONTAP in NetApp Workload Factory
Known limitations identify platforms, devices, or functions that this release of Amazon FSx for NetApp ONTAP in NetApp Workload Factory doesn't support or that don't interoperate correctly with it. Review these limitations carefully.
Region support
The following AWS regions are not supported:
China regions
Secret Cloud
Top Secret Cloud
Adding HA pairs limitations
This operation might take approximately 30 minutes to complete.
Adding HA pairs limits the following operations: adding more HA pairs, provisioning IOPS, increasing SSD capacity, and updating throughput capacity.
Throughput capacity region support
Scale-up deployments
Scale-up configurations are supported up to 2 GB/s in all regions. The following regions support up to 4 GB/s maximum throughput capacity for scale-up deployments: US East (Ohio) Region, US East (N. Virginia) Region, US West (Oregon) Region, and Europe (Ireland).
Scale-out deployments
The following regions support up to 6 GB/s maximum throughput capacity for scale-out deployments: US East (N. Virginia and Ohio), US West (N. California and Oregon), Europe (Frankfurt, Ireland, and Stockholm), and Asia Pacific (Singapore and Sydney).
Capacity management
The volume autogrow feature isn't currently supported for the iSCSI protocol.
When the automatic capacity management feature is running, manual capacity increase isn't allowed.
Disabling the automatic capacity management feature is only possible with the same permissions used to enable it.
When automatic capacity management is enabled, a link is required to make sure volume inodes increase along with storage capacity.
Storage VMs
The number of storage VMs is limited per SKU. Creating storage VMs beyond the limitation isn't supported in Workload Factory.1
Refer to Managing FSx for ONTAP storage virtual machines in AWS documentation for the maximum number of SVMs per file system.
iSCSI protocol support
The iSCSI protocol is only available for FlexVol volumes. 1
Volume size decreases aren't supported for iSCSI volumes.
Data protection
Snapshots cannot be deleted.
When you replicate a file system, all volumes in the file system use the same replication policy.
For long-term retention replication relationships, only the last snapshot is available for restore.
The following features aren't supported with immutable snapshots:
Consistency groups
FabricPool
FlexCache volumes
SMtape
SnapMirror active sync
SnapMirror policy rules using the -schedule parameter
SnapMirror synchronous
SVM data mobility (used for migrating or relocating an SVM from a source cluster to a destination cluster)
Storage savings calculator
The Storage savings calculator doesn't calculate cost savings for the following configurations:
FSx for Windows File Server: HDD storage type
Elastic Block Store (EBS): st1, sc1, and standard volume types
Elastic File System (EFS): Bursting throughput mode
AWS Secrets Manager support
AWS Secrets Manager isn't supported when using a Console agent.
Amazon S3 access points limitation
The limit for the number of S3 access points per storage VM is 4,000.
Limitations for storage VM migration replication
Workload Factory doesn't support migration replication for storage VMs between first and second generation FSx for ONTAP file systems.
Cut over replication isn't supported for volumes with S3 access points or ONTAP S3 configurations including object-store-server, buckets, users, groups, or policies on the vserver.
Note:
Applies to Amazon FSx for NetApp ONTAP
