Learn about Amazon FSx for NetApp ONTAP in NetApp Workload Factory
Amazon FSx for NetApp ONTAP is a fully managed, cloud-based data storage service that provides advanced data management capabilities and highly scalable performance. FSx for ONTAP allows you to create and manage file systems as the storage backend for all your workloads within NetApp Workload Factory.
FSx for ONTAP provides the same features, performance, and administrative capabilities NetApp customers use on premises today, with the simplicity, agility, security, and scalability of a native AWS service.
FSx for ONTAP is the Storage component in Workload Factory.
Features
FSx for ONTAP offers the following features:
Fully managed service: provides a fully managed service integrated with the Workload Factory console.
High availability: provides high availability for each FSx for ONTAP file system, supporting Single and Multiple Availability Zones deployments.
Automated snapshots: protects data with automated, efficient snapshots, which are near-instantaneous, space-efficient point-in-time read-only copies of the file system or volumes.
Volume replication: provides disaster recovery with cross-region replication across Amazon Web Services.
Efficient backups: adds an extra layer of protection with a copy of the data in another region for emergencies.
Fast cloning: accelerates application development with fast cloning.
Multi-protocol support: supports Network File System (NFS), Server Message Block (SMB), and Internet Small Computer Systems Interface (iSCSI) protocols.
High throughput: delivers high throughput performance to ensure low latencies for workloads running on top of FSx for ONTAP file systems.
In-memory cache and NVMe cache: includes a unique in-memory cache and NVMe cache, which boosts the performance of frequently accessed data.
Hundreds of thousands of IOPS: provides hundreds of thousands of IOPS with SSD disks, ensuring that your storage and workloads receive timely results.
Thin Provisioning: allows capacity provisioning in advance, saving costs until more capacity is needed.
Data deduplication and compression: removes duplicate data and compresses data to reduce the amount of physical storage required for FSx for ONTAP file systems, resulting in cost savings.
Data tiering: allows storage cost reduction by moving less frequently accessed data from the primary, high performance SSD storage tier to the secondary capacity pool storage tier.
Additional features in Workload Factory
Storage cost comparison calculator: compares your Amazon Elastic Block Store (EBS), Elastic File System (EFS) and FSx for Windows File Server storage costs with FSx for ONTAP. From the calculator, you can view how FSx for ONTAP storage configurations offer potential savings and plan your move to FSx for ONTAP storage.
Workload Factory user interface: provides Quick create and Advanced create deployment mode options. Quick create includes AWS, NetApp, and industry standard best practices for your storage configurations. The interface also shows SSD storage capacity and throughput usage trends, workload summaries, and detailed configuration settings you can expand.
Codebox: provides developers with a code viewer for FSx for ONTAP operations, code templates for copy and download, and an automation catalog for code reuse.
Tools to use NetApp Workload Factory
You can use NetApp Workload Factory with the following tools:
Workload Factory console: The Workload Factory console provides a visual, holistic view of your applications and projects.
NetApp Console: The NetApp Console provides a hybrid interface experience so that you can use Workload Factory along with other NetApp data services.
Ask me: Use the Ask me AI assistant to ask questions and learn more about Workload Factory without leaving the Workload Factory console. Access Ask me from the Workload Factory help menu.
CloudShell CLI: Workload Factory includes a CloudShell CLI to manage and operate AWS and NetApp environments across accounts from a single, browser-based CLI. Access CloudShell from the top bar of the Workload Factory console.
REST API: Use the Workload Factory REST APIs to deploy and manage your FSx for ONTAP file systems and other AWS resources.
CloudFormation: Use AWS CloudFormation code to perform the actions you defined in the Workload Factory console to model, provision, and manage AWS and third-party resources from the CloudFormation stack in your AWS account.
NetApp Terraform provider: Use Terraform to build and manage infrastructure workflows generated in the Workload Factory console.
Cost
AWS maintains your FSx for ONTAP account, not Workload Factory. Refer to Pricing for Amazon FSx for NetApp ONTAP.
Regions
Workload Factory is supported in all commercial regions where FSx for ONTAP is supported. View supported Amazon regions.
The following AWS regions aren't supported:
China regions
Secret Cloud
Top Secret Cloud
Getting help
Amazon FSx for NetApp ONTAP is an AWS first-party solution. For questions or technical support issues associated with your FSx for ONTAP file system, infrastructure, or any solution using this service, use the Support Center in your AWS Management Console to open a support case with AWS. Select the “FSx for ONTAP” service and appropriate category. Provide the remaining information required to create your AWS support case.
For general questions about Workload Factory or Workload Factory applications and services, refer to Get help for FSx for ONTAP for Workload Factory.
