Amazon FSx for NetApp ONTAP
Limit the max transfer rate of a replication relationship
Contributors netapp-rlithman
Limit the max transfer rate of a replication relationship in NetApp Workload Factory. An unlimited transfer rate might negatively impact the performance of other applications and your network.
About this task
Limiting the max transfer rate is optional but recommended. Without a limit, network and application performance might decline.
Alternatively, we recommend an unlimited transfer rate for FSx for ONTAP file systems for critical workloads, for example, those that are used primarily for disaster recovery.
Before you begin
Consider how much bandwidth to allocate for replication.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actionsenu of the file system to update and then select Manage.
  5. From the file system overview, select the Replication relationships tab.
  6. In the Replication relationships tab, select the actionsenu of the replication relationship to limit the max transfer rate for.
  7. Select Edit max transfer rate.
  8. In the Edit max transfer rate dialog, select Limited and enter the max transfer limit in MB/s.
    Alternatively, select Unlimited.
  9. Select Apply.
