Manage FSx for ONTAP cache volumes with NetApp Workload Factory
Use the NetApp Workload Factory console to manage cache volumes for FSx for ONTAP file systems. Caching, a method for temporarily storing data, improves data access performance by reducing retrieval time. You can edit the cache name, adjust capacity, change the export policy, select a caching method, prepopulate the cache, or delete cache volumes.
You can manage cache volumes that are associated with cache relationships in the NetApp Workload Factory console.
You must associate a link to manage cache volumes and relationships. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
You must have an existing cache volume to edit.
Edit the cache volume name
Change the name of an existing cache volume at any time.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system with the cache volume and then select Manage.
From the file system overview, select the Cache relationships tab.
Select the actions menu for the cache volume you want to modify and then select Edit cache name.
In the Edit cache name dialog, enter the new name for the cache volume and then select Apply.
Adjust the capacity of a cache volume
You can adjust the capacity of an existing cache volume at any time.
Select the menu
Select the actions menu for the cache volume you want to modify and then select Adjust cache capacity.
In the Adjust cache capacity dialog, enter the new capacity for the cache volume by percentage or by unit and then select Apply.
Edit the cache volume export policy
Change the mount path or the export policy assigned to an existing cache volume.
Select the menu
Select the actions menu for the cache volume you want to modify and then select Edit export policy.
In the Edit export policy dialog, change the mount path or select a different export policy to assign to the cache volume.
Select Apply.
Change the caching method for a cache volume
You can change how the cache works for an existing cache volume to write-around or write-back.
Learn more about write modes.
Select the menu
Select the actions menu for the cache volume you want to modify and then select Change caching method.
In the Change caching method dialog, select the new caching method and then select Apply.
Prepopulate a cache volume
Fill the cache volume with data from the origin volume before you use it to make cached data available faster.
Select the menu
Select the actions menu for the cache volume you want to modify and then select Prepopulate cache.
In the Prepopulate cache dialog, specify the path to the data set to use for prepopulation and then select Apply.
Delete a cache volume
When you delete a cache volume, you remove its cache relationship. Cached data is no longer available.
Select the menu
Select the actions menu for the cache volume you want to delete and then select Delete cache volume.
In the Delete cache volume dialog, confirm the deletion and then select Delete.
