Amazon FSx for NetApp ONTAP
Manage capacity and inodes automatically in NetApp Workload Factory
Contributors netapp-rlithman
Enabling capacity management lets NetApp Workload Factory automatically add incremental storage to an FSx for ONTAP file system as capacity needs change over time. Additionally, enabling this feature removes the need to monitor capacity manually.
About this task
The system scans the FSx for ONTAP file system every 30 minutes. It checks if incremental storage needs to be added and verifies available volume inodes. The count increases based on automatic capacity management thresholds.
Enabling inode management lets NetApp Workload Factory automatically add incremental inodes to an FSx for ONTAP file system as capacity needs change. This feature removes the need for manual inode monitoring.
Only one account can manage this feature.
The maximum amount of SSD storage capacity for all FSx for ONTAP file systems is 524,288 GiB. To request a quota increase, refer to Quotas in AWS FSx for NetApp ONTAP documentation.
Enable automatic capacity management and capacity notifications
Enable automatic capacity management to automatically add incremental storage up to the maximum size limit for an FSx for ONTAP file system. Set up notifications to get alerts when the file system reaches a certain capacity threshold.
Before you begin
Consider the following before you begin:
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the file system to enable automatic capacity for.
  5. In the Automatic capacity management card, select Manage.
  6. Select the capacity management method. The options are incremental and adaptive modes.
    • Incremental: increases capacity by a fixed amount at thresholds.
      • Threshold: Set the threshold lower than the incremental increase to trigger a notification from the Workload Factory notification service. The default is 70%.
        The threshold setting is available only if you enabled the Workload Factory notification service.
      • Incremental increase: Enter the maximum percentage increase for the FSx for ONTAP file system. The default is 80%.
        This is the threshold at which Workload Factory triggers a job to increase the capacity. For example, if the file system reaches 80% of capacity, then Workload Factory increases capacity.
    • Adaptive: predicts and changes capacity based on historical data.
      • Look-back: Set the analysis period in hours to determine how much historical data to consider for capacity predictions. The default is 120 hours.
      • Plan ahead: Set the buffer time in hours to ensure capacity is increased before it's actually needed. The default is 48 hours.
  7. Select Enable automatic capacity management and the credentials view, planning, and analysis permissions.
    Alternatively, disable the feature. If you need to increase file system capacity, you must first disable automatic capacity management.
  8. Select Enable capacity notifications to turn on notifications when capacity reaches the threshold you set and whenever Workload Factory performs an automatic capacity increase. The default is 70%.
    The capacity notification setting is available only if you enabled the Workload Factory notification service and when automatic capacity management is enabled.
  9. Select Apply.
Result
A file system scan occurs every 30 minutes to determine whether it needs additional capacity.
Enable inode management for a file system
Enable automatic inode management to increase the number of inodes (files) per volume up to the allowable limit.
A scan of the FSx for ONTAP file system occurs every 30 minutes. It verifies available volume inodes and checks if incremental inodes need to be added. The count increases based on automatic inode management thresholds.
Note Terraform users: Terraform has a limitation that requires that all operations are completed within Terraform. Inode management isn't supported in Terraform, but you can enable automatic inode management in the Workload Factory console.
Before you begin
Steps
  4. From FSx for ONTAP, select the actions menu of the file system to enable automatic inodes management for.
  5. Select Manage.
  6. Under Information, select the pencil icon next to Automatic inodes management. The pencil icon appears next to the drop down arrow when the mouse hovers over the Automatic inodes management row.
  7. In the Automatic inodes management dialog, provide the following:
    1. Credentials: Select credentials with Automate permissions from the dropdown menu.
    2. Select the enable button to Enable automatic inodes management.
      Alternatively, disable the feature. If you need to increase the number of inodes, you must first disable automatic inodes management.
    3. Warning threshold: Set the warning threshold lower than the threshold increase to trigger a notification from the Workload Factory notification service. The default is 70%.
      The warning threshold setting is available only if you enabled the Workload Factory notification service.
    4. Threshold increase: Enter the maximum percentage increase for the number of inodes (files) per volume. The default is 80%.
    5. Incremental increase: Enter the percentage to increase the number of inodes (files) incrementally. The default is 10%.
  8. Select Apply.
Result
A file system scan occurs every 30 minutes to determine if the volumes need additional inodes (files) per volume.
