Manage snapshot policies for volumes in NetApp Workload Factory
Manage snapshot policies for FSx for ONTAP volumes in Workload Factory. A snapshot policy defines how the system creates snapshots for a volume.
Snapshot management operations like assigning, changing, and deleting snapshot policies for volumes in an FSx for ONTAP file system are managed at the storage VM level. Snapshot policies can be shared with a single storage VM or with all storage VMs.
Some management tasks require you to associate a link with the FSx for ONTAP file system. Learn about Workload Factory links.
By default, every volume is associated with the file system's default snapshot policy. We recommend using this policy for most workloads.
Assign a snapshot policy to a volume
You can assign a snapshot policy to a single volume to create scheduled snapshots for the volume.
You must associate a link to assign a snapshot policy. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
In the FSx for ONTAP tab, select the actions menu of the file system that contains the volume to assign a snapshot policy to and then select Manage.
In the file system overview, select the Storage VMs tab.
From the Storage VMs tab, select the actions menu for the storage VM containing the volume to protect with scheduled snapshots, then Advanced actions, and then Manage snapshot policies.
On the Snapshot policy management page, select the actions menu of the snapshot policy and then select Assign policy to volume.
In the Assign snapshot policy dialog, select a snapshot policy to assign to the volume and review the policy schedule.
If the policy contains immutable snapshots and you want to use it, accept the statement.
Select Assign.
The snapshot policy is assigned to the volume.
Change a snapshot policy
You can change the snapshot policy name, schedule, and number of copies to retain, and enable or disable immutable snapshots. You can't enable or disable policy sharing across storage VMs. You can set this option only when you create a snapshot policy.
To display existing snapshot policies, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
Select the menu
In the FSx for ONTAP tab, select the actions menu of the file system and then select Manage.
On the Snapshot policy management page, select the actions menu for the snapshot policy to change and then select Edit.
In the Edit snapshot policy dialog, make the necessary changes to the snapshot policy.
Select Apply.
The snapshot policy is updated.
Enable immutable snapshots
Lock snapshots to prevent them from being deleted during the retention period.
You must associate a link to enable immutable snapshots. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
Select the menu
In the FSx for ONTAP tab, select the actions menu of the file system that contains the volume to lock snapshots for and then select Manage.
In the file system overview, select the Volumes tab.
From the Volumes tab, select the actions menu for the volume to protect.
Select Data protection actions, Snapshots, then Make a snapshot immutable.
In the Make a snapshot immutable dialog, do the following:
Snapshot name: Select the snapshot to lock.
Set the Retention period in number of hours, days, months, or years.
Accept the statement.
Select Apply.
The volume snapshot is now locked.
Enable long-term snapshot retention in NetApp Workload Factory
In NetApp Workload Factory, you can enable snapshots for long-term retention, which lets you replicate specific snapshots for long-term disaster recovery.
Long-term retention enables business services to continue operating even in the event of a complete site failure, supporting transparent failover of applications using a secondary copy.
The same steps apply for enabling and editing snapshots for long-term retention.
When an on-premises ONTAP cluster is the target for the replication relationship, changing snapshots for long-term retention isn't supported.
Editing long-term retention isn't available when replicating storage VM data and configuration settings. |
Select the menu
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
From the file system overview, select the Replication relationships tab.
In the Replication relationships tab, select the actions menu of the replication relationship schedule to change.
Select Edit long-term retention.
In the Edit long-term retention dialog, enable or disable snapshots for long-term retention.
If you select to disable snapshots for long-term retention, select Apply to complete this operation.
If you select to enable snapshots for long-term retention, choose between selecting an existing policy or creating a new policy.
To use an existing policy, select it from the dropdown menu.
To create a new policy, provide the following:
Policy name: Enter a policy name.
Snapshot policies: Select one or more snapshot policies.
Copies to retain: Enter the number of snapshot copies to retain on the target file system.
Select Apply.
Remove a snapshot policy from a volume
Remove a snapshot policy from a volume because you no longer want snapshots of the volume or because you want to delete a snapshot policy that is assigned to multiple volumes. To delete a snapshot policy that is assigned to more than one volume, you must manually remove it from all volumes.
You must associate a link to remove a snapshot policy. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
Select the menu
In the Assign snapshot policy dialog, select None to remove the snapshot policy.
Select Assign.
The snapshot policy is removed from the volume.
Delete a snapshot policy
Delete a snapshot policy when you no longer need it.
When a snapshot policy is assigned to more than one volume, you must manually remove it from all volumes to delete the snapshot policy. Alternatively, you can assign a different snapshot policy to the volumes.
Select the menu
From FSx for ONTAP, select the actions menu of the file system with the volume and then select Manage.
From the Storage VMs tab, select the actions menu of the storage VM with the snapshot policy to delete, then Advanced actions, and then Manage snapshot policies.
On the Snapshot policy management page, select the actions menu for the snapshot policy to delete and then select Delete.
In the Delete dialog, select Delete to delete the policy.
