Amazon FSx for NetApp ONTAP
Manage storage VM tags in NetApp Workload Factory
Contributors netapp-rlithman
Tags can help you categorize your resources. You can add, edit, and remove tags for a storage VM at any time in NetApp Workload Factory.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system with the storage VM to update and then select Manage.
  5. In the file system overview under Storage VMs, select Manage.
  6. From the Manage storage VMs screen, select the actions menu of the storage VM to edit tags for, then select Basic actions > Edit storage VM tags.
  7. On the Edit storage VM tags page, add, edit, or remove tags.
    The maximum number of tags you can apply to a storage VM is 50.
  8. Select Apply.
