Amazon FSx for NetApp ONTAP
Manage volume settings in NetApp Workload Factory
Contributors netapp-rlithman
Customize FSx for ONTAP volume settings in NetApp Workload Factory to fit your organization's needs. You can set volume workloads and tags to categorize resources, update storage efficiency settings to optimize space and cost savings, and manage immutable files settings to control data retention and protect against unauthorized changes.
Change volume workload
Update the workloads for a volume to match its intended use cases.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select Volumes explorer.
  4. Select the actions menu for the volume to update the workload for.
  5. Select Advanced actions then Change workloads.
  6. In the Change workloads dialog, select the correct workloads for the volume.
  7. Select Apply to save the changes.
Manage volume tags
Tags can help you categorize your resources. You can add, edit, and remove volume tags at any time for FSx for ONTAP volumes in NetApp Workload Factory.
Steps
  4. Select the actions menu for the volume to modify tags for.
  5. Select Basic actions then Edit volume tags.
  6. On the Edit volume tags page, add, edit, or remove tags.
    The maximum number of tags you can apply to a volume is 50.
  7. Select Apply.
Update volume storage efficiency
Update the storage efficiency setting after volume creation.
The storage efficiency feature includes deduplication, data compression, and data compaction to achieve optimal space savings on a FlexVol volume. Deduplication eliminates duplicate data blocks. Data compression compresses the data blocks to reduce the amount of physical storage that is required. Data compaction stores more data in less space to increase storage efficiency.
If you chose not to enable storage efficiency when you created a volume, you can enable the setting for potential space and cost savings at any time.
Volumes use thin provisioning whether you enable or disable storage efficiency.
Steps
  4. Select the actions menu of the volume to update the storage efficiency setting for.
  5. Select Advanced actions, then Set storage efficiency.
  6. Choose to enable or disable volume storage efficiency.
  7. Select Apply to save the change.
Manage immutable files for a volume in NetApp Workload Factory
You can update certain immutable files settings for a volume when the feature is enabled, such as the retention policy and periods, the autocommit period, and volume append mode.
You can enable immutable files only during volume creation.
Steps
  4. Select the actions menu of the volume to update.
  5. Select Data protection actions, then Manage immutable files.
  6. On the Manage Immutable files page, you can update the following:
    • Retention period: select Unspecified or Specify period.
      • Unspecified: The default minimum period is 0 years and the default maximum period is 30 years.
      • Specify period: Option to define the retention policy, minimum and maximum periods, the autocommit feature, and the volume append mode feature. Provide the following details:
        • Retention policy: This period must be greater than or equal to the minimum retention period and less than or equal to the maximum retention period.
        • Minimum and maximum periods: Set the minimum and maximum periods to commit files in this volume to an immutable WORM state.
    • Autocommit: enable or disable the feature to automatically commit files to WORM that haven't been modified during the Autocommit period.
    • Privileged delete: Enable or disable the feature. Enabling the feature allows a SnapLock administrator to delete an unexpired WORM volume. This feature is only supported in Enterprise retention mode.
    • Volume append mode: enable or disable the feature. Enabling volume append mode lets you add new content to WORM files.
  7. Select Apply.
