Manage volume tags in NetApp Workload Factory
Tags can help you categorize your resources. You can add, edit, and remove volume tags at any time for FSx for ONTAP volumes in NetApp Workload Factory.
Steps
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu for the volume to modify tags for.
Select Basic actions then Edit volume tags.
On the Edit volume tags page, add, edit, or remove tags.
The maximum number of tags you can apply to a volume is 50.
Select Apply.
