Amazon FSx for NetApp ONTAP
Provision SSD IOPS for an FSx for ONTAP file system
Contributors netapp-rlithman
Automatically or manually provision SSD IOPS for an FSx for ONTAP file system in NetApp Workload Factory to control the performance available to your workloads.
About this task
You can enable automatic SSD IOPS provisioning for an FSx for ONTAP file system or manually provision IOPS.
Automatically provisioned IOPS are calculated as three IOPS per GiB.
If you manually provision IOPS, you might need to increase IOPS before increasing file system capacity.
For information about IOPS limits, refer to Quotas in AWS FSx for NetApp ONTAP documentation.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to provision IOPS for and then select Manage.
  5. Under Information, select the pencil icon that appears next to the dropdown arrow when the mouse hovers over the IOPS allocation row.
  6. In the Provisioned IOPS dialog, select Automatic or User provisioned.
  7. If you select User provisioned, enter the desired IOPS value.
  8. Select Apply.
