Quick start for Amazon FSx for NetApp ONTAP in NetApp Workload Factory
With Amazon FSx for NetApp ONTAP in NetApp Workload Factory, you can get started immediately in basic mode.
If you'd like to use Workload Factory to create a file system, manage resources, and more, you can get started in a few steps. In this case, you need an AWS account and credentials to get started.
Follow these steps to get started.
Log in to Workload FactoryYou'll need to set up an account with Workload Factory and log in.
Add credentials and permissionsChoose the permission policies to meet your needs.
If you choose not to grant permissions, you can start using Workload Factory for FSx for ONTAP to copy partially completed code samples.
If you choose to grant permissions, you'll need to add credentials to an account manually that includes selecting workload capabilities, such as Databases and AI, and creating the IAM policies for the required permissions.
Create a file systemYou'll create an FSx file system to begin managing your storage and FSx for ONTAP resources in Workload Factory. In the Workload Factory console, in Storage, select Create file system. Learn how to create a file system.
You can also start with the storage savings calculator to compare the costs of your Amazon Elastic Block Store, Elastic File System, and FSx for Windows File Server storage environments to that of FSx for ONTAP. Explore savings with the storage savings calculator.
With a file system in your Storage inventory, you can create volumes, manage your FSx for ONTAP file system, and set up data protection for your resources.
