Protect FSx for ONTAP data with NetApp Autonomous Ransomware Protection with AI
Protect your data with NetApp Autonomous Ransomware Protection with AI (ARP/AI). It monitors activity in NAS (NFS/SMB) and SAN environments to detect unusual behavior that could signal a ransomware attack. If a threat is detected, ARP/AI automatically creates new immutable snapshots so you can restore your data.
Use ARP/AI to protect against denial-of-service attacks where the attacker withholds data until a ransom is paid. ARP/AI offers real-time ransomware detection based on:
Identification of the incoming data as encrypted or plaintext.
Analytics that detect:
Entropy: An evaluation of the randomness of data in a file (used in both NAS and SAN environments)
File extension types: An extension that does not conform to the normal extension type (used in NAS environments only)
File IOPS: A surge in abnormal volume activity with data encryption (used in NAS environments only)
ARP/AI can detect the spread of most ransomware attacks after only a small number of files are encrypted, take action automatically to protect data, and alert you that a suspected attack is happening.
The ARP/AI feature automatically updates according to the ONTAP version that Amazon FSx for NetApp ONTAP runs so you don't have to make manual updates.
- Learning and active modes
ARP/AI behavior depends on the protocol and volume type:
NAS volumes (NFS/SMB): ARP/AI starts working as soon as you enable it. It uses a pre-trained AI model to detect ransomware threats immediately.
SAN volumes (beginning with ONTAP 9.17.1): ARP/AI provides immediate protection, even during the first evaluation period. During this 2-4 week period, the system learns normal encryption activity and sets alert thresholds. At the same time, it continues to monitor your data, detect threats, and send alerts.
Active mode: When active mode is on, FSx for ONTAP creates ARP/AI snapshots to help protect your data when it detects a possible threat.
If the system flags a file extension as unusual, review the alert. You can respond to the alert to protect your data, or mark it as a false positive if the activity is expected.
When you mark an alert as a false positive, the system updates its alert settings. For example, if a new file extension triggers an alert and you mark it as a false positive, you will not receive an alert the next time the system sees that file extension.
- Unsupported configurations
ARP/AI doesn't support these configurations.
NVMe volumes
iSCSI volumes with ONTAP versions earlier than 9.17.1
Enable ARP/AI for a file system or a volume
Turning on ARP/AI for a file system automatically protects all current and new NAS volumes (NFS/SMB). Starting with ONTAP 9.17.1, it also supports SAN volumes (iSCSI). You can also turn on ARP/AI for specific volumes.
If ARP/AI detects a real attack after it is enabled, Workload Factory automatically creates a snapshot policy. This policy can create up to six snapshots every four hours. Each snapshot is locked for 2-5 days.
To enable ARP/AI for a file system or a volume, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system to enable ARP/AI and then select Manage.
Under Information, select the pencil icon next to Autonomous Ransomware Protection. The pencil icon appears next to the arrow when the mouse hovers over the Autonomous Ransomware Protection row.
From the NetApp Autonomous Ransomware Protection with AI (ARP/AI) page, do the following:
Enable or disable the feature.
Automatic snapshot creation: Select the maximum number of snapshots to retain and the interval of time between taking snapshots. The default is 6 snapshots every 4 hours.
Immutable snapshots: Select the default retention period in hours and the maximum number of days to retain immutable snapshots. Enable this option to ensure that snapshots cannot be deleted or modified until the specified retention period ends.
Detection: Optionally, select any of the following parameters to automatically scan and detect anomalies.
Accept the statement to proceed.
Select Apply to save the changes.
Select the menu
From the Storage menu, select Volumes explorer.
Select the actions menu of the volume to enable ARP/AI, then Data protection actions, and then Manage ARP/AI.
In the Manage ARP/AI dialog, do the following:
Validate ransomware attacks
Determine if an attack is a false alarm or a genuine ransomware incident.
Select the menu
From FSx for ONTAP, select the file system to validate ransomware attacks for.
From the file system overview, select the Volumes tab.
Select Analyze attacks from the Autonomous Ransomware Protection tile.
Download the attack events report to review if any files or folders were compromised and then decide if an attack has occurred.
If no attack occurred, select False alarm for the volume in the table and then select Close.
If an attack has occurred, select Real attack for the volume in the table. The Restore compromised volume data dialog opens. You can proceed to recover your data immediately or select Close and come back to complete the recovery process later.
Recover data after a ransomware attack
When the system detects a possible attack, it creates and locks a snapshot of the volume at that moment.
If the attack is later confirmed, you can restore affected files or the entire volume from the snapshot.
Locked snapshots cannot be deleted until the retention period expires. If the attack is later identified as a false alarm, the locked snapshot is deleted.
Because the system identifies the affected files and the time of the attack, you can recover only the affected files from available snapshots instead of restoring the entire volume.
Select the menu
From FSx for ONTAP, select the file system to recover data for.
In the Restore compromised volume data dialog, follow the instructions to restore at the file-level or at the volume-level. In most cases, you'll restore files rather than an entire volume.
After you complete the restore, select Close.
The compromised data has been restored.
