Reset the storage VM password in NetApp Workload Factory
Reset the password for a storage VM in NetApp Workload Factory when necessary.
Steps
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system with the storage VM password to reset and then select Manage.
In the file system overview under Storage VMs, select Manage.
From the Manage storage VMs screen, select the actions menu of the storage VM to reset the password for, then select Basic actions > Reset password.
In the Reset password dialog, provide the following:
New password: Enter a new password for the storage VM.
Confirm password: Enter the new password again to confirm.
Select Apply.
