Set volume latency thresholds in NetApp Workload Factory
Set latency thresholds for volumes to receive alerts when read or write latency exceeds specified values.
You can configure latency thresholds on a per-volume basis to monitor performance and receive alerts when latency values exceed your defined limits. Workload Factory monitors both read and write latency and generates alerts when either threshold is exceeded.
When you set latency thresholds, Workload Factory monitors the following:
Read latency: Triggers an alert when read operations exceed the specified threshold in milliseconds.
Write latency: Triggers an alert when write operations exceed the specified threshold in milliseconds.
Latency monitoring uses the following default parameters:
IOPS threshold: 100 IOPS (read and write)
Time range: 10 minutes
An alert is generated when the latency threshold is exceeded and the IOPS threshold is met over the specified time range.
You can view latency events and receive alerts without a link connection. However, to analyze events and receive AI-powered insights and recommendations, you must connect to the file system using a link. |
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu of the volume to set latency thresholds for.
Select Alerts actions, then Set latency threshold.
In the Set latency threshold dialog, configure the following:
Read latency: Enter the threshold value in milliseconds (ms) for read operations.
Write latency: Enter the threshold value in milliseconds (ms) for write operations.
Select Save to apply the latency thresholds.
Workload Factory monitors the volume and generates alerts when read or write latency exceeds the configured thresholds. You can view latency events from the Analysis screen.
