Amazon FSx for NetApp ONTAP
Track replication delays in NetApp Workload Factory
Contributors netapp-rlithman
Turn on tracking to monitor replication delays across your account. Workload Factory alerts you when delays go beyond a set threshold. By default, the threshold is 150% of the replication interval to allow normal transfer time and reduce false alarms. You can adjust the threshold to match your RPO and get notifications when delays exceed it. You can also export the data to a CSV file for further analysis.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
  5. From the file system overview, select the Replication relationships tab.
  6. Select Enable tracking.
  7. In the Enable replication lag history dialog, select Enable.
  8. Back in the Replication lag history tile, select Customize threshold to set your preferred threshold.
  9. In the Customize lag time threshold dialog, enter the threshold in hours and minutes.
  10. Optionally, select Enable lag time notifications to receive notifications when replication lag exceeds the threshold.
    Notifications come in an email and include:
    • Source file system
    • Source volume
    • Target file system
    • Target volume
    • Lag time threshold that was exceeded
    • Link to the replication relationship
  11. Select Apply.
Related information
Manage replication relationships
