Amazon FSx for NetApp ONTAP
Update throughput capacity for a file system in NetApp Workload Factory
Contributors netapp-rlithman
Update throughput capacity for an FSx for ONTAP file system in NetApp Workload Factory as needed.
For throughput capacity limits, refer to Quotas in AWS FSx for NetApp ONTAP documentation.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to update throughput capacity for and then select Manage.
  5. Under Information, select the pencil icon next to Throughput capacity. The pencil icon appears next to the drop down arrow when the mouse hovers over the Throughput capacity row.
  6. In the Throughput capacity dialog, select the throughput capacity you need.
  7. Select Apply to save the changes.
