Activate external authentication for a GenAI knowledge base
Activate authentication for a knowledge base so that token validation and ACLs are required when using the API endpoints to integrate a knowledge base with a chatbot application. When you activate authentication, you configure settings for a JSON Web Token that will be used for API requests to a knowledge base from chatbot clients.
Log in to workload factory using one of the console experiences.
From the Knowledge bases inventory page, select the knowledge base for which you want to activate authentication.
Select
and select Manage knowledge base.
Select the Actions menu and select Manage authentication settings.
Set up authentication:
Select Activate authentication settings.
Provide the required information. Examples are provided, but you should obtain the values for these fields from your authentication provider:
Algorithms: The signing algorithm that your authentication provider uses.
Audience (Optional): A string containing the intended recipient of the token (sometimes a URL).
Issuer: A string that identifies the provider that issued the token.
For example, Amazon Cognito uses issuer strings with the following format:
https://cognito-idp-<region>.amazonaws.com/<UserPoolID>
Where
<region>
is the AWS region containing the user pool, and<UserPoolID>
is your user pool ID. You can retrieve your user pool ID using the following command:aws cognito-idp list-user-pools --max-results=60 --output=table
JWKS URI: The URI string that provides public keys needed to verify signatures of this token.
For example, Amazon Cognito uses JWKS URI strings with the following format:
https://cognito-idp.<region>.amazonaws.com/<userPoolId>/.well-known/jwks.json
Where
<region>
Select Save.
Authentication for the knowledge base is now active, and you can use API endpoints to interact with the knowledge base and integrate the knowledge base with a chatbot application.
