Manage the GenAI infrastructure
You can view details about your deployed GenAI RAG infrastructure or remove the chatbot infrastructure if you no longer need it.
View information about the infrastructure
You can view information about the chatbot infrastructure.
Log in to workload factory using one of the console experiences.
From the workload factory navigation menu, select AI.
Select the Infrastructure tab.
View information about the infrastructure, which includes details about the following components:
AWS settings
Infrastructure settings
The AI engine
The vector database
Remove the infrastructure
If you no longer need the chatbot infrastructure that you deployed for one or more chatbots, you can remove it from workload factory.
All chatbots that have been deployed on this infrastructure will be disabled and all chat history will be deleted. |
This operation only removes the links to the AI infrastructure from workload factory—it does not remove all the components from AWS. You'll need to manually delete the following infrastructure components from AWS:
The VM instance
Private endpoints
The volume on the FSx for ONTAP file system that contains the AI databases
The IAM role
The policy
The security group
Select
and select Remove chatbot infrastructure.
Confirm that you want to delete the infrastructure and select Remove.
The chatbot infrastructure components are removed from workload factory.
