Information Security for Workload Factory
Data handling and residency for NetApp Workload Factory
Contributors netapp-rlithman
NetApp Workload Factory organizes data handling into categories that describe the operational data the service processes, how each data class fits within the security model, where data is stored, how long it's retained, and whether it leaves the customer environment. The primary data classes include configuration and metadata, operational logs and events, and telemetry. Retained data can include FSx for ONTAP configuration snapshots, credential references, AI usage and cost data, audit records, and short-lived response caches. Storage and processing locations vary by data type: some information stays in the customer AWS account, while other operational data is stored in the NetApp account.
Data classes handled by Workload Factory
Workload Factory handles the following data classes:
  • Configuration and metadata
  • Operational logs and events
  • Telemetry
Data classes retained by Workload Factory
Workload Factory keeps the following data:
  • FSx configuration snapshots (refreshed on each scan)
  • ONTAP credential references, or credential material encrypted with KMS envelope encryption (depending on selected credential mode)
  • EDA metrics
  • CloudFormation templates (7-day Expires header)
  • AI usage and cost data
  • Audit records
  • Redis caches (FSx responses) with a 20-minute TTL
Where information is kept
AWS account
  • ONTAP admin passwords are stored in your AWS Secrets Manager.
  • Amazon Bedrock processes AI inference (EMS analysis) using your inference profile ARN through an STS-assumed role within your AWS account.
NetApp account
  • FSx configurations, balance plans, ARP configurations, and AI usage limits
  • Temporary AWS STS credentials (cached in Redis), response caches, locks, and deployment state
  • CloudFormation/Terraform templates, well-architected configuration descriptors, and compressed reports
  • AI usage metering and collector performance metrics
  • EDA aggregated metrics
  • Action audit trails
  • OpenTelemetry traces
Region considerations
  • Stored in regions where the Amazon Bedrock service is available.
  • NetApp internal operates in us-east-1 and us-west-2.
How long information is kept
This section summarizes retention categories. Refer to the linked pages for detailed values and policy behavior.
What information leaves the VPC
This section summarizes outbound data categories. Refer to linked pages for protocol-level and feature-level details.
Management plane traffic to the Workload Factory service
For management operations, FSx configuration, volume metadata, resource identifiers, and operational commands flow over HTTPS to the Workload Factory service tier.
Audit records to the NetApp Console Audit Service
Every tracked operation sends the following information:
  • accountId
  • actionName
  • status
  • resourceId
  • userId
  • requestData
  • responseData
  • timestamps
  • IP address
  • workspaceId
AI analysis traffic
FSx for ONTAP Emergency Management System (EMS) events, latency data, and error logs submitted for AI diagnostics travel to Amazon Bedrock through your AWS account using your configured inference profile, so this traffic stays within your environment rather than reaching NetApp systems.
For more information about AI analysis traffic, refer to:
Telemetry and metrics collection
Configuration and metadata collection scope
File system level
  • File system configuration (deployment type Gen1/Gen2, throughput capacity, storage capacity, storage type)
  • Preferred subnet, security groups, VPC configuration
  • KMS encryption key metadata
  • File system tags
  • File system lifecycle status
  • Maintenance window settings
Volume level (comprehensive)
  • Identity and state: volume name, UUID, type (rw/dp/ls), style (FlexVol/FlexGroup), state (online/offline/restricted), creation time
  • Capacity: total size, used, available, physical used, percent used, SSD footprint, capacity pool footprint, inactive data bytes/percent
  • Tiering: policy (all/auto/none/snapshot_only), minimum cooling days
  • QoS: assigned QoS policy name
  • NAS configuration: junction path, export policy assignment, UNIX permissions, security style (unix/ntfs/mixed)
  • Snapshots: snapshot reserve size/percent/used, autodelete settings
  • Data efficiency: compression type/state, deduplication, compaction, space savings
  • Autosize: mode (grow/grow_shrink/off), min/max size, grow/shrink thresholds
  • SnapLock: type (compliance/enterprise/non_snaplock), retention periods (min/max/default), autocommit period
  • Clone: parent volume/snapshot/storage VM, is FlexClone, split status
  • Inodes/files: maximum possible, maximum configured, used count
  • Encryption: enabled/disabled status
  • Access time: atime update enabled/disabled and update period
  • SnapMirror: protection status, destination types (cloud/ONTAP)
  • FlexGroup rebalancing: imbalance percent, max threshold
  • Volume movement: destination aggregate, movement state
  • FlexCache endpoint type: none/cache/origin
  • Tags: ONTAP-level volume tags
Snapshot data
  • Snapshot name, UUID, creation time, expiry time
  • Size in bytes
  • SnapMirror label
  • SnapLock expiry and lock status
  • State (valid/invalid/partial)
  • User comments
  • Snapshot policies: name, enabled status, schedule copies (count, retention period, schedule name, prefix, SnapMirror label)
Export policies
  • Policy name, ID, associated storage VM
  • Rules: protocol list (NFS/CIFS/FlexCache), client match patterns, read-only rules, read/write rules, superuser rules, rule index/priority
  • SUID, device creation, chown mode, anonymous user mapping, NTFS UNIX security settings
S3 access points
  • Lifecycle state (available/creating/deleting/failed/misconfigured)
  • Creation time, ARN, alias, name
  • Files owner user and type (UNIX/WINDOWS)
  • Network configuration (Internet vs VPC access, VPC ID)
  • AWS tags
  • Metadata scan enablement, journaling enablement, CloudTrail ARN
Anti-Ransomware Protection (ARP)
Workload Factory collects both configuration status and event details:
  • State per volume (enabled/disabled/dry_run/paused)
  • Attack probability (none/low/moderate/high)
  • Attack reports with timestamps
  • Detection parameters: file extension thresholds, rename rate surge %, entropy rate surge %, file create/delete rate surge %
  • Suspected files: file path, file name, file format, suspect time, associated volume
Replication / SnapMirror
  • Relationship UUID, state, healthy status
  • Source and destination (storage VM, path, cluster)
  • Transfer statistics (bytes transferred, duration, end time, state)
  • Policy (name, type: async/sync/continuous)
  • Throttle setting
  • Lag time
  • Unhealthy reasons (message and code)
  • Current transfer errors
iGroups
  • Name, UUID, protocol (FCP/iSCSI/mixed), OS type
  • Initiators (IQN/WWPN), connectivity state, last seen time
  • LUN mappings (logical unit number, LUN details)
LUNs
  • Name, UUID, serial number, OS type, enabled status
  • Size, used space, thin provisioning settings
  • Location (volume, node, logical unit path)
  • Auto-delete setting
  • Container state, mapped status, read-only status
  • QoS policy
  • Performance metrics (IOPS, latency, throughput per read/write/total)
  • Consistency group membership
FlexCache
  • Origin volume/storage VM/cluster, cache size, path
  • Writeback enabled, DR cache status
  • Relative sizing configuration
  • Prepopulate directory paths
  • Connection status between cache and origin
Storage VM level
  • Name, UUID, state (running/stopped), subtype
  • Protocols enabled/allowed (NFS, CIFS, iSCSI, FCP, NVMe, S3)
  • DNS servers and domains
  • Name service switch configuration (passwd, group, hosts, etc.)
  • IP interfaces (name, IP address, services)
  • Assigned aggregates
  • Anti-ransomware default volume state
  • Space enforcement settings
  • Peer relationships (applications, state, remote cluster/storage VM)
Aggregate / storage level
  • Aggregate name, UUID, state, RAID state
  • Block storage: disk count, RAID size, available/used/total space, physical used
  • Cloud storage used
  • Efficiency: ratio, logical used, savings
  • Encryption, mirror, SnapLock settings
  • Performance metrics (IOPS, latency, throughput)
Utilization metrics (EDA)
  • Collection cadence: every 12 hours for capacity/throughput; every 20 minutes for latency
  • Granularity: normalized to approximately 60 datapoints per time range
  • Retention and storage details: Metrics and telemetry reference
