Information Security for Workload Factory
Learn about the Lambda link for NetApp Workload Factory
Contributors netapp-rlithman
NetApp Workload Factory uses a link, an AWS Lambda function deployed in your VPC, to keep ONTAP-native operations inside your AWS account boundary when the Amazon FSx for NetApp ONTAP API doesn't expose those operations. The link runs in your subnets and security groups, so the execution component remains within your AWS environment. Workload Factory invokes the link only for operations that require direct ONTAP access rather than an available AWS service API. It compares the link's architecture with the security and operational profile of the NetApp Console agent.
A Workload Factory link creates a trust relationship and indirect connectivity between a Workload Factory account and one or more FSx for ONTAP file systems.
The following table provides an overview of the Lambda link security architecture. Use this information to understand how the Lambda function is deployed and executed in your AWS account, including its networking configuration, runtime environment, and operational limits.
Property Detail
Compute
AWS Lambda (container image)
Runtime
Node.js 22
Deployment
CloudFormation stack in your AWS account
VPC placement
Your subnets, your security groups
Timeout
10 seconds per invocation
Invocation
Synchronous (RequestResponse)
Package type
Container image (from NetApp ECR)
The following diagram shows the security architecture of the Lambda link.
Diagram showing the security architecture of the Lambda link.
The Lambda link and the NetApp Console agent serve different purposes and have different security and operational implications.
Dimension Link (Lambda-based) NetApp Console agent (VM/Pods-based)
Runtime model
Serverless (AWS Lambda), customer-deployed
Customer-deployed VM/containers; runs NetApp console service pods
Primary scope
Control-plane ONTAP REST operations (only when AWS APIs do not support the operation)
Orchestration plus support for data services
Data services support
Does not host data services
Can host data services (runs NetApp console service pods)
Operational overhead
No always-on VM
VM lifecycle management and upgrades
For the full cross-system connectivity map, refer to Connectivity and trust paths for NetApp Workload Factory.
