Setup and administration
Learn about the AI agents in NetApp Workload Factory
Contributors netapp-sineadd netapp-rlithman
Workload Factory AIOps uses AI agents to analyze your environment, identify risks, and recommend improvements. If you approve, the agents can also take actions using the credentials and permissions you set up.
Note If your account admin has turned off AI features, you'll see a message and won't be able to use the agents. Contact your administrator or learn about AI administration.
Before you begin
Make sure your Workload Factory account has AWS credentials and the IAM permissions agents need for the resources they access. If you enable read/write mode, those permissions must also allow supported changes.
Data usage and privacy
Your data is not used to train AI models. Agents use your credentials to securely access AWS resources through standard AWS APIs and respond based on your actual environment. All agent activity follows NetApp privacy policies and AWS security controls.
Why use AI agents
AI agents help you work more efficiently in Workload Factory:
  • Get answers and recommendations based on your environment.
  • Identify risks and optimization opportunities.
  • Troubleshoot issues and take approved actions in one workflow.
  • Run scheduled checks and receive updates in chat history.
  • Work across FSx for ONTAP and Google Cloud NetApp Volumes environments.
Access the AI agents
From the Ask Me homepage
On the Ask Me landing page, select Explore Agents. The AI agents side panel opens with a welcome message introducing the agents' capabilities.
From the agents redirection links
When you use Ask Me or other features, you might see links that redirect you to the agents for more advanced assistance.
How AI agents work
How agents access your environment
Agents can access resources only when the resources are included in your current Workload Factory scope and supported by the credentials selected in Agents settings. Agents can operate only where both controls apply. The resources they can access also depend on the permissions assigned to their AWS credentials. By default, all credentials are selected, but you can limit the selection to a subset of your configured credentials.
Your current scope includes:
  • AWS accounts: Which AWS accounts agents can access.
  • Credentials: Which credentials agents can use.
  • Regions: Which AWS regions agents can access.
Filters in Workload Factory set the scope for the current page, such as the AWS accounts and regions in view. Agents settings control which credentials agents are allowed to use within that scope. Access to resources also depends on the IAM permissions assigned to those credentials.
Note Selecting a credential in Agents settings does not grant additional AWS permissions. Make sure the credentials have the IAM permissions required for agents to access the resources you want them to analyze or manage.
Read-only mode (default)
By default, the agents operate in read-only mode. In this mode, they can:
  • Answer questions about your environment.
  • Analyze your FSx for ONTAP file systems, databases, and workloads.
  • Identify risks, misconfigurations, and optimization opportunities.
  • Provide recommendations for improving performance, availability, protection, and cost-efficiency.
  • Troubleshoot issues and suggest remediation steps.
They can't change resources in read-only mode. If you request an action that needs write access, the agent explains the limitation and links to Agents settings.
Read/write mode (opt-in)
You can enable read/write capabilities in Agents settings. In this mode, agents explain each supported action and require your approval before making any changes.
This approval process applies to all agent experiences, including Slack integrations and NetApp Console.
Audit and tracking for agent actions
In read/write mode, Tracker records each approval request, including the agent's question and the user's answer. The Workload Factory service that performs the operation logs resource changes made through Workload Factory APIs. For example, a volume created through Workload Factory appears under the Storage service tag, not Agent.
What users see when AI agents have no data or activity
If agents don't have credentials, they can still provide general guidance. However, they can't review your resources or give insights specific to your environment.
