Setup and administration
Manage AI features in NetApp Workload Factory
Contributors netapp-sineadd netapp-rlithman
Control access to AI features in Workload Factory. You can turn off AI features or use AWS Bedrock managed by NetApp or your organization.
About AI features
Workload Factory includes several AI-powered features that enhance your experience such as Ask Me, AI agents, custom dashboards, Rule builder, and analyzers for EMS, database logs, and latency.
As a Workload Factory administrator, you can control how these features use AI on the AI settings page.
Configuration options
Choose from these setup options:
NetApp-managed Bedrock (Recommended)
Use a NetApp-managed AWS Bedrock service. This option is recommended for most users.
  • Your data is not used to train models
  • Monthly usage credits are shared across your organization
  • No additional AWS setup is required
Customer-managed Bedrock
Use your own AWS Bedrock configuration.
  • For best results, NetApp recommends using Anthropic Claude Sonnet 4.5 or 4.6 with your Amazon Bedrock configuration
GenAI features off
Turns off all AI features. Users can no longer use Ask Me, the AI Agent, analyzers, custom dashboards, rules builder, or other AI-powered tools.
Before you begin
  • We recommend that an account admin set up AI features.
  • If you use customer-managed Bedrock, update the AWS policy for the credentials linked to the Workload Factory IAM role.
Note Add the required permissions to the AWS policy for the credentials linked to the Workload Factory IAM role.
Configure AI features
Steps
  1. Log in using one of the console experiences.
  2. From the menu, select Administration > Settings > AI tools.
  3. On the AI tools page, select your preferred configuration:
    • NetApp-managed Bedrock (Recommended): Use NetApp-managed AWS Bedrock.
    • Customer-managed Bedrock:
      1. Select the AWS credentials and region associated with the Workload Factory IAM role
      2. Provide the inference profile that you want to use
      3. Select Validate configuration.
        Workload Factory shows a notification indicating whether the connection succeeds or fails
    • GenAI features off: Turn off all AI features.
  4. Select Save changes.
Result
Your settings are saved and applied immediately to all AI features in Workload Factory. You can view in Tracker who last updated the settings and when.
If AI features are turned off, users see a message when they try to use AI-powered features. The interface remains visible and clearly shows that the feature is unavailable.
Budget controls and credit limits
NetApp manages budget controls for AI features only when you use the default, NetApp-managed configuration.
Monthly credit limits
Each account has a monthly spending limit for each AI feature when using NetApp-managed Bedrock.
When budget is reached
If your account reaches the monthly budget limit, Workload Factory will:
  • Turn off AI features and gray out related parts of the interface
  • Show this message as a tooltip: “Monthly AI credits reached. Contact NetApp Support.”
  • Log usage for tracking purposes
Request additional credits
If you need more AI credits, contact your NetApp representative. They can adjust your credit limit based on your needs.
Tip
To contact your NetApp representative about credit limits, use the in-product chat or visit the Get help page.
GovCloud considerations
If you create a Workload Factory account in AWS GovCloud (US), note that AI features use AWS Bedrock services in public AWS Regions by default.
If your security requirements do not allow connections to public AWS Region services, you can disable AI features.
Impact on existing sessions
When you change AI settings, any active AI sessions are softly terminated. Current workflows can finish, but new requests use the updated settings.
Termination behavior may vary by feature. See the feature-specific documentation for details.
