Setup and administration
Learn about NetApp Workload Factory
Contributors netapp-rlithman netapp-sineadd netapp-bcammett netapp-tonacki netapp-mwallis
NetApp Workload Factory is a powerful life-cycle management platform designed to help you optimize your workloads using Amazon FSx for NetApp ONTAP file systems. Workloads that can be streamlined using Workload Factory and FSx for ONTAP include databases, VMware migrations to VMware Cloud on AWS, AI chatbots, and more.
A workload encompasses a combination of resources, code, and services or applications, designed to serve a business goal. This could be anything from a customer-facing application to a backend process. Workloads may involve a subset of resources within a single AWS account or span across multiple accounts.
Amazon FSx for NetApp ONTAP provides fully managed, AWS-native NFS, SMB/CIFS, and iSCSI storage volumes for mission-critical applications, databases, containers, VMware Cloud datastores, and user files. You can manage FSx for ONTAP through Workload Factory and by using native AWS management tools.
Features
The Workload Factory platform provides the following major capabilities.
Flexible and low cost storage
Discover, deploy, and manage Amazon FSx for NetApp ONTAP file systems in the cloud. FSx for ONTAP brings the full capabilities of ONTAP to a native AWS managed service delivering a consistent hybrid cloud experience.
Lambda link connectivity
Use Lambda link connectivity to create a trust relationship and connectivity between a Workload Factory account and one or more FSx for ONTAP file systems. Links let you monitor and manage certain file system features directly from the ONTAP REST API calls that are not available through the Amazon FSx for ONTAP API.
Migrate on-premises vSphere environments to VMware Cloud on AWS
The VMware Cloud on AWS migration advisor enables you to analyze your current virtual machine configurations in on-premises vSphere environments, generate a plan to deploy recommended VM layouts to VMware Cloud on AWS, and use customized Amazon FSx for NetApp ONTAP file systems as external datastores.
Database lifecycle management
Discover database workloads and analyze costs savings with Amazon FSx for NetApp ONTAP; leverage storage and application benefits when migrating SQL server databases to FSx for ONTAP storage; deploy SQL servers, databases, and database clones that implement vendor best practices; use an Infrastructure as Code co-pilot to automate operations; and continuously monitor and optimize SQL server estates to improve performance, availability, protection, and cost-efficiency.
EDA storage operations
Streamline your Electronic Design Automation (EDA) storage operations in NetApp Workload Factory by optimizing performance, integrating with your IaC to automate storage parameters, and ensuring operational health.
Savings calculators to save costs
Analyze your current deployments that use Amazon Elastic Block Store (EBS) or Elastic File System (EFS) storage, or Amazon FSx for Windows File Server, to see how much money you can save by moving to Amazon FSx for NetApp ONTAP. You can also use the calculator to perform a "what if" scenario for a future deployment that you're planning.
Service accounts to promote automation
Use service accounts to automate NetApp Workload Factory operations securely and reliably. Service accounts provide reliable, long-lasting automation without any user management restrictions and are more secure because they only provide API access.
Ask Me AI assistant
Ask the AI assistant questions about managing and running FSx for ONTAP and Google Cloud NetApp Volumes. Ask Me securely connects to your environment and uses APIs to provide answers based on your storage setup.
Example prompts:
  • Check the health and lifecycle status of all FSx for NetApp ONTAP file systems every hour to catch issues early.
  • List all accessible AWS FSx file systems every hour to keep an up-to-date inventory.
AI agents
Workload Factory AIOps uses AI to analyze your environment and recommend improvements. If you approve, it can also take actions using the credentials and permissions you set up. The AI agents help Ask Me give you insights using your connected accounts. Open the “Explore Agents” section in Ask Me to get quick answers, identify risks and opportunities, troubleshoot issues, and receive recommendations. By default, agents can only view information. In read-write mode, they can take actions across AWS, ONTAP, and supported APIs only after you approve them. You can also use credentials from multiple AWS accounts, add custom prompts, and choose how much detail to include in responses, including reasoning and tool activity in Slack. Learn about the AI agents.
Note Account administrators can turn AI features on or off. If an administrator turns them off, the Ask Me AI assistant and AI agents will not be available. Learn about managing AI features.
Supported cloud providers
Workload Factory enables you to manage cloud storage and use workload capabilities in Amazon Web Services.
Security
Security for NetApp Workload Factory is a top priority for NetApp. All workloads in Workload Factory run atop Amazon FSx for NetApp ONTAP. In addition to all AWS security features, NetApp Workload Factory has received SOC2 Type 1 compliance, SOC2 Type 2 compliance, and HIPAA compliance.
Amazon FSx for NetApp ONTAP for NetApp Workload Factory is an AWS solution for deploying enterprise apps that was created with well-architected best practices in mind.
Cost
Workload Factory is free to use. The cost that you pay to Amazon Web Services (AWS) depends on the storage and workload services that you plan to deploy. This includes the cost of Amazon FSx for NetApp ONTAP file systems, VMware Cloud on AWS infrastructure, AWS services, and more.
How Workload Factory works
Workload Factory includes a web-based console that's provided through the SaaS layer, an account, operational modes that control access to your cloud estate, links that provide segregated connectivity between Workload Factory and an AWS account, and more.
Software-as-a-service
Workload Factory is accessible through the NetApp Workload Factory console and the NetApp Console. These SaaS experiences enables you to automatically access the latest features as they're released and to easily switch between your Workload Factory accounts and links.
Accounts
When you log in to Workload Factory for the first time, you're prompted to create an account. This account enables you to organize your resources, workloads, and workload access for your organization using credentials.
A screenshot of the Workload Factory setup wizard that prompts you for the Workload Factory account.
When you create an account, you are the single account admin user for that account.
If your organization requires additional account or user management, reach out to us by using the in-product chat.
Tip If you use the NetApp Console, then you'll already belong to an account because Workload Factory leverages NetApp accounts.
Service accounts
A service account acts as a "user" that can make authorized API calls to NetApp Workload Factory for automation purposes. This makes it easier to manage automation because you don't need to build automation scripts based on a real person's user account who can leave the company at any time. All account holders in Workload Factory are considered account admins. Account admins can create and delete multiple service accounts.
Permissions
Workload Factory provides flexible permission policies that enables you to carefully control access to your cloud estate, and assign incremental trust to Workload Factory based on your IT policies.
A Workload Factory link creates a trust relationship and connectivity between Workload Factory and one or more FSx for ONTAP file systems. This enables you to monitor and manage certain file system features directly from the ONTAP REST API calls that are not available through the Amazon FSx for ONTAP API.
You don't need a link to get started with Workload Factory, but in some cases you'll need to create a link to unlock all Workload Factory features and workload capabilities.
Links currently leverage AWS Lambda.
Codebox automation
Codebox is an Infrastructure as Code (IaC) co-pilot that helps developers and DevOps engineers generate the code needed to execute any operation supported by Workload Factory. Code formats include Workload Factory REST API, AWS CLI, and AWS CloudFormation.
Codebox is aligned with the Workload Factory operation modes (basic, read-only, and read/write) and sets a clear path for execution readiness as well as an automation catalog for quick future reuse.
The Codebox pane shows the IaC that is generated by a specific job flow operation, and is matched by a graphical wizard or conversational chat interface. While Codebox supports color coding and search for easy navigation and analysis, it does not allow editing. You can only copy or save to the Automation Catalog.
Savings calculators
Workload Factory provides savings calculators so you can compare the costs of your storage environments, database, or VMware workloads on FSx for ONTAP file systems against other Amazon services. Depending on your storage requirements, you might find that FSx for ONTAP file systems are the most cost effective option for you.
Well-architected workloads
Workload Factory helps you maintain and operate reliable, secure, efficient, and cost-effective storage and database configurations that align with the AWS Well-Architected Framework. Workload Factory scans FSx for ONTAP file systems, SQL Server, and Oracle database deployments daily to provide insights into potential misconfigurations and recommends either manual or automated actions for fixing issues.
Tools to use NetApp Workload Factory
You can use NetApp Workload Factory with the following tools:
  • Workload Factory console: The Workload Factory console provides a visual, holistic view of your applications and projects.
  • NetApp Console: The NetApp Console provides a hybrid interface experience so that you can use Workload Factory along with other NetApp data services.
  • Ask me: Use the Ask me AI assistant to ask questions and learn more about Workload Factory without leaving the Workload Factory console. Access Ask me from the Workload Factory help menu.
  • CloudShell CLI: Workload Factory includes a CloudShell CLI to manage and operate AWS and NetApp environments across accounts from a single, browser-based CLI. Access CloudShell from the top bar of the Workload Factory console.
  • REST API: Use the Workload Factory REST APIs to deploy and manage your FSx for ONTAP file systems and other AWS resources.
  • CloudFormation: Use AWS CloudFormation code to perform the actions you defined in the Workload Factory console to model, provision, and manage AWS and third-party resources from the CloudFormation stack in your AWS account.
  • NetApp Terraform provider: Use Terraform to build and manage infrastructure workflows generated in the Workload Factory console.
REST APIs
Workload Factory enables you to optimize, automate, and operate your FSx for ONTAP file systems for specific workloads. Each workload exposes an associated REST API. Collectively, these workloads and APIs form a flexible and extensible development platform you can use to administer your FSx for ONTAP file systems.
There are several benefits when using the Workload Factory REST APIs:
  • The APIs have been designed based on REST technology and current best practices. The core technologies include HTTP and JSON.
  • Workload Factory authentication is based on the OAuth2 standard. NetApp relies on the Auth0 service implementation.
  • The Workload Factory web-based console uses the same core REST APIs so there is consistency between the two access paths.
Region support
The following AWS regions are not supported:
  • China regions
  • Secret Cloud
  • Top Secret Cloud
