Connect your FSx for ONTAP file systems to VMware Cloud on AWS
Contributors netapp-bcammett netapp-tonacki netapp-sineadd
After you deploy FSx for ONTAP file systems, you need to connect that system to your VMware Cloud on AWS infrastructure. Your Software-Defined Data Center (SDDC) offers network options for connecting to the FSx for ONTAP file system by using the VPC peering capability to extend network connectivity to the external NFS storage volumes.
The following diagram shows how to use VPC peering to connect single Availability Zone (AZ) SDDC clusters to FSx for ONTAP single-AZ deployments.
A diagram showing how to use VPC Peering for connecting single-AZ SDDC clusters to FSx for ONTAP single-AZ deployments.
