Create a new role binding for a user in a group
POST /accounts/{account_id}/core/v1/groups/{group_id}/users/{user_id}/roleBindings
Indicates desired values for the Role Binding API resource to be created.
account_id  |
string  |
path  |
True  |
group_id  |
string  |
path  |
True  |
ID of the containing group resource  |
user_id  |
string  |
path  |
True  |
ID of the containing user resource  |
Request Body
| Name | Type | Required | Description |
type  |
string  |
True  |
version  |
string  |
True  |
userID  |
string  |
False  |
JSON string containing a user resource ID. Defined values are:
groupID  |
string  |
False  |
JSON string containing a group resource ID. Defined values are:
accountID  |
string  |
True  |
JSON string containing the ID of an account resource. For create, this must match the account ID in the request URI. Defined values are:
role  |
string  |
True  |
JSON string containing one of the four defined roles. Defined values are:
roleConstraints  |
array[string]  |
False  |
JSON array of JSON strings specifying the scope of the role assignment. Defined values are:
metadata  |
False  |
Example request
  "type": "application/astra-roleBinding",
  "version": "1.1",
  "userID": "4c27d25a-9edb-4e85-9438-48dc8e917231",
  "accountID": "9fd87309-067f-48c9-a331-527796c14cf3",
  "role": "viewer",
  "roleConstraints": [
Status: 201, Returns the newly created roleBinding resource in the JSON response body.
type  |
string  |
True  |
version  |
string  |
True  |
id  |
string  |
True  |
principalType  |
string  |
True  |
JSON string representing the type of the principal this binding is associated with. Defined values are:
userID  |
string  |
True  |
groupID  |
string  |
True  |
accountID  |
string  |
True  |
role  |
string  |
True  |
roleConstraints  |
array[string]  |
False  |
metadata  |
True  |
  "version": "1.1",
  "id": "a198f052-5cd7-59d3-9f27-9ea32a21fbca",
  "principalType": "user",
  "groupID": "00000000-0000-0000-0000-000000000000",
  "role": "viewer",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type  |
string  |
True  |
title  |
string  |
True  |
detail  |
string  |
True  |
status  |
string  |
True  |
correlationID  |
string  |
False  |
  "status": "401"
Status: 400, Bad request
type  |
string  |
True  |
title  |
string  |
True  |
detail  |
string  |
True  |
status  |
string  |
True  |
correlationID  |
string  |
False  |
invalidFields  |
array[invalidFields]  |
False  |
List of invalid request body fields  |
  "status": "400"
Status: 409, Conflict
type  |
string  |
True  |
title  |
string  |
True  |
detail  |
string  |
True  |
status  |
string  |
True  |
correlationID  |
string  |
False  |
invalidFields  |
False  |
  "status": "409"
Status: 403, Forbidden
type  |
string  |
True  |
title  |
string  |
True  |
detail  |
string  |
True  |
status  |
string  |
True  |
correlationID  |
string  |
False  |
  "status": "403"
Status: 404, Not found
type  |
string  |
True  |
title  |
string  |
True  |
detail  |
string  |
True  |
status  |
string  |
True  |
correlationID  |
string  |
False  |
Example error response
  "status": "404"
type_astra_label
name  |
string  |
True  |
value  |
string  |
True  |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels  |
array[type_astra_label]  |
False  |
creationTimestamp  |
string  |
False  |
modificationTimestamp  |
string  |
False  |
createdBy  |
string  |
False  |
modifiedBy  |
string  |
False  |
invalidParams
name  |
string  |
True  |
Name of the invalid query parameter  |
reason  |
string  |
True  |
Reason why the query parameter is invalid  |
invalidFields
name  |
string  |
True  |
Name of the invalid request body field  |
reason  |
string  |
True  |
Reason why the request body field is invalid  |
