Element Software
SSL 密码
贡献者 netapp-pcarriga netapp-yvonneo amgrissino
SSL 密码是主机用来建立安全通信的加密算法。Element 软件支持标准密码,而启用 FIPS 140-2 模式时则支持非标准密码。
以下列表提供了 Element 软件支持的标准安全套接字层( SSL )密码以及启用 FIPS 140-2 模式时支持的 SSL 密码:
  • 已禁用 * FIPS 140-2 *
    tls_DHE_RSA_WIT_AES_128_CBC_SHA256 ( DH 2048 ) - A
    tls_DHE_RSA_WIT_AES_128_GCM_SHA256 ( DH 2048 ) - A
    tls_DHE_RSA_WIT_AES_256_CBC_SHA256 ( DH 2048 ) - A
    tls_DHE_RSA_WIT_AES_256_GCM_SHA384 ( DH 2048 )— A
    tls_ECDHE_RSA_WIT_AES_128_CBC_SHA256 ( secp256r1 )— A
    tls_ECDHE_RSA_WIT_AES_128_GCM_SHA256 ( secp256r1 )— A
    tls_ECDHE_RSA_WITE_AES_256_CBC_SHA384 ( secp256r1 )— A
    tls_ECDHE_RSA_WIT_AES_256_GCM_SHA384 ( secp256r1 )— A
    tls_rsa_and_3DES_EDE_CBC_SHA ( RSA 2048 ) - C
    tls_rsa_and_aes_128_cbc_sha ( RSA 2048 )— A
    tls_rsa_and_aes_128_cbc_SHA256 ( RSA 2048 ) - A
    tls_rsa_and_aes_128_gcm_SHA256 ( RSA 2048 )— A
    tls_rsa_and_aes_256_cbc_sha ( RSA 2048 )— A
    tls_rsa_and_aes_256_cbc_SHA256 ( RSA 2048 ) - A
    tls_rsa_and_aes_256_gcm_SHA384 ( RSA 2048 )— A
    tls_rsa_and_Camellia_128_CBC_SHA ( RSA 2048 )— A
    tls_rsa_and_Camellia_256_CBC_SHA ( RSA 2048 )— A
    tls_rsa_and_ide_cbc_sha ( RSA 2048 )— A
    tls_rsa_and_rc4_128_md5 ( RSA 2048 ) - C
    tls_rsa_and_rc4_128_sha ( RSA 2048 ) - C
    tls_rsa_and_seed_cbc_sha ( RSA 2048 )— A
  • 已启用 * FIPS 140-2
    tls_ECDHE_RSA_WITE_AES_128_CBC_SHA256 ( sect571r1 )— A
    tls_ECDHE_RSA_WIT_AES_128_GCM_SHA256 ( sect571r1 )— A
    tls_ECDHE_RSA_WITE_AES_256_CBC_SHA384 ( sect571r1 )— A
    tls_ECDHE_RSA_WIT_AES_256_GCM_SHA384 ( sect571r1 )— A
