NetApp data management solutions
从 7-模式到ONTAP 的数据迁移
贡献者 kevin-hoke
本节提供将数据从以 7 模式运行的NetApp Data ONTAP迁移到ONTAP的详细步骤。
将 7 模式 NFSv3 存储过渡到ONTAP以用于 NFS 数据
本节提供了下表中将源 7-模式 NFSv3 导出过渡到ONTAP系统的分步过程。
NetApp假定源 7-模式 NFSv3 卷已导出并安装在客户端系统上,并且 XCP 已安装在 Linux 系统上。
  1. 验证目标ONTAP系统是否正常。
    CLUSTER::> cluster show
    Node                  Health  Eligibility
    CLUSTER-01            true    true
    CLUSTER-02            true    true
    2 entries were displayed.
    CLUSTER::> node show
    Node      Health Eligibility Uptime        Model       Owner    Location
    CLUSTER-01
              true   true        78 days 21:01 FAS8060              RTP
    CLUSTER-02
              true   true        78 days 20:50 FAS8060              RTP
    CLUSTER::> storage failover show
                                  Takeover
    Node           Partner        Possible State Description
    CLUSTER-01     CLUSTER-02     true     Connected to CLUSTER-02
    CLUSTER-02     CLUSTER-01     true     Connected to CLUSTER-01
  2. 验证目标系统上是否存在至少一个非根聚合。总量正常。
    CLUSTER::> storage aggregate show
    Aggregate     Size Available Used% State   #Vols  Nodes            RAID Status
    aggr0      368.4GB   17.85GB   95% online       1 CLUSTER-01       raid_dp,
        normal
    aggr0_CLUSTER_02_0
               368.4GB   17.85GB   95% online       1 CLUSTER-02       raid_dp,
        normal
    source      1.23TB    1.10TB   11% online       6 CLUSTER-01       raid_dp,
        normal
    3 entries were displayed.
    如果没有数据聚合,请使用 `storage aggr create`命令。
  3. 在目标集群系统上创建存储虚拟机 (SVM)。
    CLUSTER::> vserver create -vserver dest -rootvolume dest_root -aggregate poc -rootvolume-security-style mixed
    [Job 647] Job succeeded:
    Vserver creation completed
    Verify the security style and language settings of the source
    Verify that the SVM was successfully created.
    CLUSTER::> vserver show -vserver dest
                                        Vserver: dest
                                   Vserver Type: data
                                Vserver Subtype: default
                                   Vserver UUID: 91f6d786-0063-11e5-b114-00a09853a969
                                    Root Volume: dest_root
                                      Aggregate: poc
                                     NIS Domain: -
                     Root Volume Security Style: mixed
                                    LDAP Client: -
                   Default Volume Language Code: C.UTF-8
                                Snapshot Policy: default
                                        Comment:
                                   Quota Policy: default
                    List of Aggregates Assigned: -
     Limit on Maximum Number of Volumes allowed: unlimited
                            Vserver Admin State: running
                      Vserver Operational State: running
       Vserver Operational State Stopped Reason: -
                              Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp
                           Disallowed Protocols: -
                Is Vserver with Infinite Volume: false
                               QoS Policy Group: -
                                    Config Lock: false
                                   IPspace Name: Default
  4. 从目标 SVM 中删除 FCP、iSCSI、NDMP 和 CIDS 协议。
    CLUSTER::> vserver remove-protocols -vserver dest -protocols fcp,iscsi,ndmp,cifs
    验证 NFS 是否是此 SVM 允许的协议。
    CLUSTER::> vserver show -vserver dest -fields allowed-protocols
    vserver allowed-protocols
    dest    nfs
  5. 在目标 SVM 上创建新的读写数据卷。验证安全模式、语言设置和容量要求是否与源卷匹配。
    CLUSTER::> vol create -vserver dest -volume dest_nfs -aggregate poc -size 150g -type RW -state online -security-style mixed
    [Job 648] Job succeeded: Successful
  6. 创建数据 LIF 来满足 NFS 客户端请求。
    CLUSTER::> network interface create -vserver dest -lif dest_lif -address 10.61.73.115 -netmask 255.255.255.0 -role data -data-protocol nfs -home-node CLUSTER-01 -home-port e0l
    验证 LIF 是否已成功创建。
    CLUSTER::> network interface show -vserver dest
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    dest
                dest_lif
                             up/up    10.61.73.113/24    CLUSTER-01    e0i     true
  7. 如果需要,使用 SVM 创建静态路由。
    CLUSTER::> network route create -vserver dest -destination 0.0.0.0/0 -gateway 192.168.100.111
    验证路线是否已成功创建。
    CLUSTER::> network route show -vserver source
    Vserver             Destination     Gateway         Metric
    dest
                        0.0.0.0/0       10.61.73.1      20
  8. 在 SVM 命名空间中挂载目标 NFS 数据卷。
    CLUSTER::> volume mount -vserver dest -volume dest_nfs -junction-path /dest_nfs -active true
    验证卷是否已成功安装。
    CLUSTER::> volume show -vserver dest -fields junction-path
    vserver volume   junction-path
    dest    dest_nfs /dest_nfs
    dest    dest_root
    您还可以使用以下命令指定卷安装选项(连接路径) `volume create`命令。
  9. 在目标 SVM 上启动 NFS 服务。
    CLUSTER::> vserver nfs start -vserver dest
    验证服务是否已启动并正在运行。
    CLUSTER::> vserver nfs status
    The NFS server is running on Vserver "dest".
    CLUSTER::> nfs show
    Vserver: dest
            General Access:  true
                        v3:  enabled
                      v4.0:  disabled
                       4.1:  disabled
                       UDP:  enabled
                       TCP:  enabled
      Default Windows User:  -
     Default Windows Group:  -
  10. 验证默认 NFS 导出策略是否已应用于目标 SVM。
    CLUSTER::> vserver export-policy show -vserver dest
    Vserver          Policy Name
    dest             default
  11. 如果需要,为目标 SVM 创建新的自定义导出策略。
    CLUSTER::> vserver export-policy create -vserver dest -policyname xcpexportpolicy
    验证新的自定义导出策略是否已成功创建。
    Vserver          Policy Name
    dest             default
    dest             xcpexportpolicy
  12. 修改导出策略规则以允许 NFS 客户端访问。
    CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0
    Verify the policy rules have modified
    CLUSTER::> export-policy rule show -instance
                                        Vserver: dest
                                    Policy Name: xcpexportpolicy
                                     Rule Index: 1
                                Access Protocol: nfs3
    Client Match Hostname, IP Address, Netgroup, or Domain: 0.0.0.0/0
                                 RO Access Rule: none
                                 RW Access Rule: none
    User ID To Which Anonymous Users Are Mapped: 65534
                       Superuser Security Types: none
                   Honor SetUID Bits in SETATTR: true
                      Allow Creation of Devices: true
  13. 验证客户端是否被允许访问该卷。
    CLUSTER::> export-policy check-access -vserver dest -volume dest_nfs -client-ip 10.61.82.215 -authentication-method none -protocol nfs3 -access-type read-write
                                             Policy    Policy       Rule
    Path                          Policy     Owner     Owner Type  Index Access
    /                             xcpexportpolicy
                                             dest_root volume          1 read
    /dest_nfs                     xcpexportpolicy
                                             dest_nfs  volume          1 read-write
  14. 连接到 Linux NFS 服务器。为 NFS 导出卷创建挂载点。
    [root@localhost /]# cd /mnt
    [root@localhost mnt]# mkdir dest
  15. 在此挂载点挂载目标 NFSv3 导出卷。
    备注 NFSv3 卷应该被导出但不一定由 NFS 服务器挂载。如果可以安装,XCP Linux 主机客户端就会安装这些卷。
    [root@localhost mnt]# mount -t nfs 10.61.73.115:/dest_nfs /mnt/dest
    验证挂载点是否已成功创建。
    [root@ localhost /]# mount | grep nfs
    10.61.73.115:/dest_nfs on /mnt/dest type nfs (rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.61.82.215,mountvers=3,mountport=4046,mountproto=udp,local_lock=none,addr=10.61.73.115)
  16. 在 NFS 导出的挂载点上创建测试文件以启用读写访问。
    [root@localhost dest]# touch test.txt
    Verify the file is created
    [root@localhost dest]# ls -l
    total 0
    -rw-r--r-- 1 root bin 0 Jun  2 03:16 test.txt
    备注 读写测试完成后,从目标NFS挂载点删除该文件。
  17. 连接到安装了 XCP 的 Linux 客户端系统。浏览到 XCP 安装路径。
    [root@localhost ~]# cd /linux/
    [root@localhost linux]#
  18. 通过运行以下命令查询源 7-模式 NFSv3 导出 `xcp show`XCP Linux 客户端主机系统上的命令。
    [root@localhost]#./xcp show 10.61.82.215
    == NFS Exports ==
    Mounts  Errors  Server
          4       0  10.61.82.215
         Space    Files      Space    Files
          Free     Free       Used     Used Export
      23.7 GiB  778,134    356 KiB       96 10.61.82.215:/vol/nfsvol1
      17.5 GiB  622,463   1.46 GiB      117 10.61.82.215:/vol/nfsvol
       328 GiB    10.8M   2.86 GiB    7,904 10.61.82.215:/vol/vol0/home
    == Attributes of NFS Exports ==
    drwxr-xr-x --- root wheel 4KiB 4KiB 2d21h 10.61.82.215:/vol/nfsvol1
    drwxrwxrwx --t root wheel 4KiB 4KiB 9d22h 10.61.82.215:/vol/vol0/home
    drwxr-xr-x --- root wheel 4KiB 4KiB  4d0h 10.61.82.215:/vol/vol0
    3.89 KiB in (5.70 KiB/s), 7.96 KiB out (11.7 KiB/s), 0s.
  19. 扫描源 NFSv3 导出路径并打印其文件结构的统计信息。
    NetApp建议在 xcp 期间将源 NFSv3 导出置于只读模式 scan, copy , 和 `sync`运营。
    [root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol
    nfsvol
    nfsvol/n5000-uk9.5.2.1.N1.1.bin
    nfsvol/821_q_image.tgz
    nfsvol/822RC2_q_image.tgz
    nfsvol/NX5010_12_node_RCF_v1.3.txt
    nfsvol/n5000-uk9-kickstart.5.2.1.N1.1.bin
    nfsvol/NetApp_CN1610_1.1.0.5.stk
    nfsvol/glibc-common-2.7-2.x86_64.rpm
    nfsvol/glibc-2.7-2.x86_64.rpm
    nfsvol/rhel-server-5.6-x86_64-dvd.iso.filepart
    nfsvol/xcp
    nfsvol/xcp_source
    nfsvol/catalog
    23 scanned, 7.79 KiB in (5.52 KiB/s), 1.51 KiB out (1.07 KiB/s), 1s.
  20. 将源 7-模式 NFSv3 导出复制到目标ONTAP系统上的 NFSv3 导出。
    [root@localhost /]# ./xcp copy 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs
     44 scanned, 39 copied, 264 MiB in (51.9 MiB/s), 262 MiB out (51.5 MiB/s), 5s
     44 scanned, 39 copied, 481 MiB in (43.3 MiB/s), 479 MiB out (43.4 MiB/s), 10s
     44 scanned, 40 copied, 748 MiB in (51.2 MiB/s), 747 MiB out (51.3 MiB/s), 16s
     44 scanned, 40 copied, 1.00 GiB in (55.9 MiB/s), 1.00 GiB out (55.9 MiB/s), 21s
     44 scanned, 40 copied, 1.21 GiB in (42.8 MiB/s), 1.21 GiB out (42.8 MiB/s), 26s
    Sending statistics...
    44 scanned, 43 copied, 1.46 GiB in (47.6 MiB/s), 1.45 GiB out (47.6 MiB/s), 31s.
  21. 复制完成后,验证源和目标 NFSv3 导出是否具有相同的数据。运行 `xcp verify`命令。
    [root@localhost /]# ./xcp verify 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs
    44 scanned, 44 found, 28 compared, 27 same data, 2.41 GiB in (98.4 MiB/s), 6.25 MiB out (255 KiB/s), 26s
    44 scanned, 44 found, 30 compared, 29 same data, 2.88 GiB in (96.4 MiB/s), 7.46 MiB out (249 KiB/s), 31s
    44 scanned, 100% found (43 have data), 43 compared, 100% verified (data, attrs, mods), 2.90 GiB in (92.6 MiB/s), 7.53 MiB out (240 KiB/s), 32s.
    如果 `xcp verify`发现源数据和目标数据之间存在差异,则错误 `no such file or directory`在摘要中进行了报告。要解决该问题,请运行 `xcp sync`命令将源更改复制到目标。
  22. 在切换之前和切换期间,运行 `verify`再次。如果源有新的或更新的数据,则执行增量更新。运行 `xcp sync`命令。
    For this operation, the previous copy index name or number is required.
    [root@localhost /]# ./xcp sync -id 3
    Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs1'}
    64 reviewed, 64 checked at source, 6 changes, 6 modifications, 51.7 KiB in (62.5 KiB/s), 22.7 KiB out (27.5 KiB/s), 0s.
    xcp: sync '3': Starting search pass for 1 modified directory...
    xcp: sync '3': Found 6 indexed files in the 1 changed directory
    xcp: sync '3': Rereading the 1 modified directory to find what's new...
    xcp: sync '3': Deep scanning the 1 directory that changed...
    11 scanned, 11 copied, 12.6KiB in (6.19KiBps), 9.50 KiB out (4.66KiBps), 2s.
  23. 要恢复先前中断的复制操作,请运行 `xcp resume`命令。
    [root@localhost /]# ./xcp resume -id 4
    Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs7'}
    xcp: resume '4': WARNING: Incomplete index.
    xcp: resume '4': Found 18 completed directories and 1 in progress
    106 reviewed, 24.2 KiB in (30.3 KiB/s), 7.23 KiB out (9.06 KiB/s), 0s.
    xcp: resume '4': Starting second pass for the in-progress directory...
    xcp: resume '4': Found 3 indexed directories and 0 indexed files in the 1 in-progress directory
    xcp: resume '4': In progress dirs: unindexed 1, indexed 0
    xcp: resume '4': Resuming the 1 in-progress directory...
     20 scanned, 7 copied, 205 MiB in (39.6 MiB/s), 205 MiB out (39.6 MiB/s), 5s
     20 scanned, 14 copied, 425 MiB in (42.1 MiB/s), 423 MiB out (41.8 MiB/s), 11s
     20 scanned, 14 copied, 540 MiB in (23.0 MiB/s), 538 MiB out (23.0 MiB/s), 16s
     20 scanned, 14 copied, 721 MiB in (35.6 MiB/s), 720 MiB out (35.6 MiB/s), 21s
     20 scanned, 15 copied, 835 MiB in (22.7 MiB/s), 833 MiB out (22.7 MiB/s), 26s
     20 scanned, 16 copied, 1007 MiB in (34.3 MiB/s), 1005 MiB out (34.3 MiB/s), 31s
     20 scanned, 17 copied, 1.15 GiB in (33.9 MiB/s), 1.15 GiB out (33.9 MiB/s), 36s
     20 scanned, 17 copied, 1.27 GiB in (25.5 MiB/s), 1.27 GiB out (25.5 MiB/s), 41s
     20 scanned, 17 copied, 1.45 GiB in (36.1 MiB/s), 1.45 GiB out (36.1 MiB/s), 46s
     20 scanned, 17 copied, 1.69 GiB in (48.7 MiB/s), 1.69 GiB out (48.7 MiB/s), 51s
    20 scanned, 20 copied, 21 indexed, 1.77 GiB in (33.5 MiB/s), 1.77 GiB out (33.4 MiB/s), 54s.
    后 `resume`完成复制文件,运行 `verify`再次确保源存储和目标存储具有相同的数据。
  24. NFSv3 客户端主机需要卸载从 7-模式存储配置的源 NFSv3 导出,并从ONTAP挂载目标 NFSv3 导出。切换需要中断。
将 7-模式卷 Snapshot 副本过渡到ONTAP
本节介绍将源 7-模式卷NetApp Snapshot 副本过渡到ONTAP的过程。
备注 NetApp假定源 7-模式卷已导出并安装在客户端系统上,并且 XCP 已安装在 Linux 系统上。 Snapshot 副本是卷的某个时间点映像,用于记录自上次 Snapshot 副本以来的增量变化。使用 `-snap`以 7 模式系统为源的选项。
*警告:*保留基本 Snapshot 副本。基线复制完成后,请勿删除基线 Snapshot 副本。进一步的同步操作需要基本 Snapshot 副本。
  1. 验证目标ONTAP系统是否正常。
    CLUSTER-01
    CLUSTER-02
                                  Takeover
        normal
    aggr0_CLUSTER_02_0
        normal
        normal
  3. 在目标集群系统上创建 SVM。
                                        Vserver: dest
                                   Vserver Type: data
                                      Aggregate: poc
                                     NIS Domain: -
                                    LDAP Client: -
                                        Comment:
                               QoS Policy Group: -
                                    Config Lock: false
  4. 从目标 SVM 中删除 FCP、iSCSI、NDMP 和 CIFS 协议。
    Verify that NFS is the allowed protocol for this SVM.
    dest    nfs
    验证 LIF 是否已成功创建。
    dest
                dest_lif
    验证路线是否已成功创建。
    dest
    验证卷是否已成功安装。
    dest    dest_root
    验证服务是否已启动并正在运行。
    CLUSTER::> nfs show
    Vserver: dest
                        v3:  enabled
                      v4.0:  disabled
                       4.1:  disabled
                       UDP:  enabled
                       TCP:  enabled
    Vserver          Policy Name
    dest             default
    验证新的自定义导出策略是否已成功创建。
    Vserver          Policy Name
    dest             default
  12. 修改导出策略规则以允许访问目标系统上的 NFS 客户端。
                                        Vserver: dest
                                     Rule Index: 1
  13. 验证客户端是否可以访问目标卷。
                                             Policy    Policy       Rule
    /                             xcpexportpolicy
    验证挂载点是否已成功创建。
    total 0
    == NFS Exports ==
          4       0  10.61.82.215
    NetApp建议在以下情况下将源 NFSv3 导出置于只读模式: xcp scan , copy , 和 `sync`运营。在 `sync`操作时,您必须通过 `-snap`具有相应值的选项。
    [root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol/.snapshot/snap1
    nfsvol
    nfsvol/catalog
    [root@scspr1202780001 vol_acl4]# ./xcp  sync -id 7msnap1  -snap 10.236.66.199:/vol/nfsvol/.snapshot/snap10
    (show scan and sync)
  20. 将源 7-模式 NFSv3 快照(基础)复制到目标ONTAP系统上的 NFSv3 导出。
    [root@localhost /]# /xcp copy 10.61.82.215:/vol/nfsvol/.snapshot/snap1
    备注 保留此基本快照以供进一步的同步操作。
    如果 `verify`发现源数据和目标数据之间存在差异,则错误 `no such file or directory `is reported in the summary. To fix that issue, run the `xcp sync`命令将源更改复制到目标。
  22. 在切换之前和切换期间,运行 `verify`再次。如果源有新的或更新的数据,则执行增量更新。如果有增量更改,请为这些更改创建一个新的 Snapshot 副本,并将该快照路径与 `-snap`同步操作的选项。
    运行 `xcp sync`命令 `-snap`选项和快照路径。
    Index: {source: '10.61.82.215:/vol/nfsvol/.snapshot/snap1', target: '10.61.73.115:/dest_nfs1'}
    11 scanned, 11 copied, 12.6 KiB in (6.19 KiB/s), 9.50 KiB out (4.66 KiB/s), 2s..
    备注 对于此操作,需要基础快照。
    [root@scspr1202780001 534h_dest_vol]# ./xcp resume -id 3
    XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxxxx [NetApp Inc] until Mon Dec 31 00:00:00 2029
    xcp: Index: {source: '10.61.82.215:/vol/nfsvol',/.snapshot/snap1, target: 10.237.160.55:/dest_vol}
    xcp: resume '7msnap_res1': Reviewing the incomplete index...
    xcp: diff '7msnap_res1': Found 143 completed directories and 230 in progress
    39,688 reviewed, 1.28 MiB in (1.84 MiB/s), 13.3 KiB out (19.1 KiB/s), 0s.
    xcp: resume '7msnap_res1': Starting second pass for the in-progress directories...
    xcp: resume '7msnap_res1': Resuming the in-progress directories...
    xcp: resume '7msnap_res1': Resumed command: copy {-newid: u'7msnap_res1'}
    xcp: resume '7msnap_res1': Current options: {-id: '7msnap_res1'}
    xcp: resume '7msnap_res1': Merged options: {-id: '7msnap_res1', -newid: u'7msnap_res1'}
    xcp: resume '7msnap_res1': Values marked with a * include operations before resume
     68,848 scanned*, 54,651 copied*, 39,688 indexed*, 35.6 MiB in (7.04 MiB/s), 28.1 MiB out (5.57 MiB/s), 5s
  24. NFSv3 客户端主机必须卸载从 7-模式存储配置的源 NFSv3 导出,并从ONTAP挂载目标 NFSv3 导出。此切换需要停机。
将 ACLv4 从NetApp 7-模式迁移到NetApp存储系统
本节介绍将源 NFSv4 导出过渡到ONTAP系统的分步过程。
备注 NetApp假定源 NFSv4 卷已导出并安装在客户端系统上,并且 XCP 已安装在 Linux 系统上。源应该是支持 ACL 的NetApp 7-模式系统。仅支持从NetApp到NetApp 的ACL 迁移。要复制名称中带有特殊字符的文件,请确保源文件和目标文件支持 UTF-8 编码语言。
将源 NFSv4 导出迁移到ONTAP 的前提条件
将源 NFSv4 导出迁移到ONTAP之前,必须满足以下先决条件:
  • 目标系统必须配置 NFSv4。
  • NFSv4 源和目标必须安装在 XCP 主机上。选择 NFS v4.0 来匹配源和目标存储,并验证源和目标系统上是否启用了 ACL。
  • XCP 要求将源/目标路径挂载到 XCP 主机上以进行 ACL 处理。在下面的示例中, `vol1(10.63.5.56:/vol1)`安装在 `/mnt/vol1`小路:
 [root@localhost ~]# df -h
Filesystem                                                   Size  Used Avail Use% Mounted on
10.63.5.56:/vol1                                             973M  4.2M  969M   1% /mnt/vol1
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/
XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029
drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1
rw-r--r-- --- root root    4    0 23h42m vol1/DIR1/FILE
drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11
rw-r--r-- --- root root    4    0 23h42m vol1/DIR1/DIR11/FILE
drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11/DIR2
rw-r--r-- --- root root    4    0 23h42m vol1/DIR1/DIR11/DIR2/FILE
drwxr-xr-x --- root root 4KiB 4KiB 17m43s vol1/DIR1/DIR11/DIR2/DIR22
8 scanned, 8 getacls, 1 v3perm, 7 acls, 3.80 KiB in (3.86 KiB/s), 1.21 KiB out (1.23 KiB/s), 0s.
子目录选项
使用子目录的两个选项如下:
  • 为了让 XCP 在子目录上工作 (/vol1/DIR1/DIR11)、挂载完整路径(10.63.5.56:/vol1/DIR1/DIR11) 在 XCP 主机上。
    如果没有挂载完整路径,XCP会报告以下错误:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/DIR1/DIR11
xcp: ERROR: For xcp to process ACLs, please mount 10.63.5.56:/vol1/DIR1/DIR11 using the OS nfs4 client.
  • 使用子目录语法(mount: subdirectory/qtree/.snapshot),如下例所示:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1:/DIR1/DIR11
drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11
rw-r--r-- --- root root    4    0 23h51m DIR11/DIR2/FILE
drwxr-xr-x --- root root 4KiB 4KiB  26m9s DIR11/DIR2/DIR22
rw-r--r-- --- root root    4    0 23h51m DIR11/FILE
drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11/DIR2
5 scanned, 5 getacls, 5 acls, 2.04 KiB in (3.22 KiB/s), 540 out (850/s), 0s.
完成以下步骤将 ACLv4 从NetApp 7-模式迁移到NetApp存储系统。
  1. 验证目标ONTAP系统是否正常。
    CLUSTER-01
    CLUSTER-02
                                  Takeover
        normal
    aggr0_CLUSTER_02_0
        normal
        normal
  3. 在目标集群系统上创建 SVM。
    验证 SVM 是否已成功创建。
                                        Vserver: dest
                                   Vserver Type: data
                                      Aggregate: poc
                                     NIS Domain: -
                                    LDAP Client: -
                                        Comment:
                               QoS Policy Group: -
                                    Config Lock: false
    dest    nfs
    验证 LIF 是否已成功创建。
    dest
                dest_lif
    验证路线是否已成功创建。
    dest
    验证卷是否已成功安装。
    dest    dest_root
    验证服务是否已启动并正在运行。
    CLUSTER::> nfs show
    Vserver: dest
                        v3:  enabled
                      v4.0:  enabled
                       4.1:  disabled
                       UDP:  enabled
                       TCP:  enabled
  10. 检查默认 NFS 导出策略是否应用于目标 SVM。
    Vserver          Policy Name
    dest             default
    验证新的自定义导出策略是否已成功创建。
    Vserver          Policy Name
    dest             default
    验证策略规则是否已被修改。
                                        Vserver: dest
                                     Rule Index: 1
  13. 验证客户端是否被允许访问该卷。
                                             Policy    Policy       Rule
    /                             xcpexportpolicy
  15. 在此挂载点挂载目标 NFSv4 导出卷。
    备注 NFSv4 卷应该被导出但不一定由 NFS 服务器挂载。如果可以安装,XCP Linux 主机客户端就会安装这些卷。
    [root@localhost mnt]# mount -t nfs4 10.63.5.56:/vol1 /mnt/vol1
    验证挂载点是否已成功创建。
    [root@localhost mnt]# mount | grep nfs
    10.63.5.56:/vol1 on /mnt/vol1 type nfs4 (rw,relatime,vers=4.0,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,
    retrans=2,sec=sys,clientaddr=10.234.152.84,local_lock=none,addr=10.63.5.56)
    验证文件是否已创建。
    total 0
  18. 通过运行以下命令查询源 NFSv4 导出 `xcp show`XCP Linux 客户端主机系统上的命令。
    root@localhost]# ./xcp show 10.63.5.56
    XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029
    getting pmap dump from 10.63.5.56 port 111...
    getting export list from 10.63.5.56...
    sending 6 mounts and 24 nfs requests to 10.63.5.56...
    == RPC Services ==
    '10.63.5.56': UDP rpc services: MNT v1/2/3, NFS v3, NLM v4, PMAP v2/3/4, STATUS v1
    '10.63.5.56': TCP rpc services: MNT v1/2/3, NFS v3/4, NLM v4, PMAP v2/3/4, STATUS v1
    == NFS Exports ==
          6       0  10.63.5.56
      94.7 MiB   19,883    324 KiB      107 10.63.5.56:/
       971 MiB   31,023   2.19 MiB       99 10.63.5.56:/vol2
       970 MiB   31,024   2.83 MiB       98 10.63.5.56:/vol1
      9.33 GiB  310,697    172 MiB      590 10.63.5.56:/vol_005
      43.3 GiB    1.10M   4.17 GiB    1.00M 10.63.5.56:/vol3
      36.4 GiB    1.10M   11.1 GiB    1.00M 10.63.5.56:/vol4
    drwxr-xr-x --- root root 4KiB 4KiB 6d2h 10.63.5.56:/
    drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol2
    drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol1
    drwxr-xr-x --- root root 4KiB 4KiB 9d2h 10.63.5.56:/vol_005
    drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol3
    drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol4
    6.09 KiB in (9.19 KiB/s), 12.2 KiB out (18.3 KiB/s), 0s.
  19. 扫描源 NFSv4 导出路径并打印其文件结构的统计信息。
    NetApp建议在以下情况下将源 NFSv4 导出置于只读模式: xcp scan , copy , 和 `sync`运营。
    [root@localhost]# ./xcp scan -acl4 10.63.5.56:/vol1
    vol1
    vol1/test/f1
    vol1/test
    3 scanned, 3 getacls, 3 v3perms, 1.59 KiB in (1.72 KiB/s), 696 out (753/s), 0s.
  20. 将源 NFSv4 导出复制到目标ONTAP系统上的 NFSv4 导出。
    [root@localhost]# ./xcp copy -acl4 -newid id1 10.63.5.56:/vol1 10.63.5.56:/vol2
    3 scanned, 2 copied, 3 indexed, 3 getacls, 3 v3perms, 1 setacl, 14.7 KiB in (11.7 KiB/s), 61 KiB out (48.4 KiB/s), 1s..
  21. 后 `copy`完成后,验证源和目标 NFSv4 导出是否具有相同的数据。运行 `xcp verify`命令。
    [root@localhost]# ./xcp verify -acl4 -noid 10.63.5.56:/vol1 10.63.5.56:/vol2
    3 scanned, 100% found (0 have data), 100% verified (data, attrs, mods, acls), 6 getacls, 6 v3perms, 2.90 KiB in (4.16 KiB/s), 2.94 KiB out (4.22 KiB/s), 0s.
    如果 `verify`发现源数据和目标数据之间存在差异,则错误 `no such file or directory`在摘要中进行了报告。要解决该问题,请运行 `xcp sync`命令将源更改复制到目标。
    [root@ root@localhost]# ./xcp sync -id id1
    xcp: Index: {source: 10.63.5.56:/vol1, target: 10.63.5.56:/vol2}
    3 reviewed, 3 checked at source, no changes, 3 reindexed, 25.6 KiB in (32.3 KiB/s), 23.3 KiB out (29.5 KiB/s), 0s.
    备注 对于此操作,需要先前的复制索引名称或编号。
  23. 恢复先前中断的 `copy`操作,运行 `xcp resume`命令。
    [root@localhost]# ./xcp resume -id id1
    xcp: Index: {source: 10.63.5.56:/vol3, target: 10.63.5.56:/vol4}
    xcp: resume 'id1': Reviewing the incomplete index...
    xcp: diff 'id1': Found 0 completed directories and 8 in progress
    39,899 reviewed, 1.64 MiB in (1.03 MiB/s), 14.6 KiB out (9.23 KiB/s), 1s.
    xcp: resume 'id1': Starting second pass for the in-progress directories...
    xcp: resume 'id1': Resuming the in-progress directories...
    xcp: resume 'id1': Resumed command: copy {-acl4: True}
    xcp: resume 'id1': Current options: {-id: 'id1'}
    xcp: resume 'id1': Merged options: {-acl4: True, -id: 'id1'}
    xcp: resume 'id1': Values marked with a * include operations before resume
     86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (2.60 MiB/s), 78.4 KiB out (15.6 KiB/s), 5s 86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (0/s), 78.4 KiB out (0/s), 10s
    1.00M scanned, 100% found (1M have data), 1M compared, 100% verified (data, attrs, mods, acls), 2.00M getacls, 202 v3perms, 1.00M same acls, 2.56 GiB in (2.76 MiB/s), 485 MiB out (524 KiB/s), 15m48s.
将 7-模式 SMB 存储过渡到ONTAP以用于 CIFS 数据
本节介绍将源 7-模式 SMB 共享过渡到ONTAP系统的分步过程。
备注 NetApp假定 7-模式和ONTAP系统是 SMB 许可的。已创建目标 SVM、导出源和目标 SMB 共享,并且已安装和许可 XCP。
  1. 扫描 SMB 共享中的文件和目录。
    C:\xcp>xcp scan -stats \\10.61.77.189\performance_SMB_home_dirs
    XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029
    == Maximum Values ==
    Size Depth Namelen Dirsize
    15.6MiB 2 8 200
    == Average Values ==
    540KiB 2 7 81
    == Top File Extensions ==
    .txt .tmp
    5601 2200
    == Number of files ==
    empty <8KiB 8-64KiB 64KiB-1MiB 1-10MiB 10-100MiB >100MiB
    46 6301 700 302 200 252
    == Space used ==
    0 6.80MiB 8.04MiB 120MiB 251MiB 3.64GiB 0
    == Directory entries ==
    empty 1-10 10-100 100-1K 1K-10K >10k
    18 1 77 1
    == Depth ==
    0-5 6-10 11-15 16-20 21-100 >100
    7898
    == Modified ==
    >1 year >1 month 1-31 days 1-24 hrs <1 hour <15 mins future
    2167 56 322 5353
    == Created ==
    2171 54 373 5300
    Total count: 7898
    Directories: 97
    Regular files: 7801
    Symbolic links:
    Junctions:
    Special files:
    Total space for regular files: 4.02GiB
    Total space for directories: 0
    Total space used: 4.02GiB
    7,898 scanned, 0 errors, 0s
  2. 将文件(带或不带 ACL)从源复制到目标 SMB 共享。以下示例显示了具有 ACL 的副本。
    C:\xcp>xcp copy -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs
    7,898 scanned, 0 errors, 0 skipped, 184 copied, 96.1MiB (19.2MiB/s), 5s
    7,898 scanned, 0 errors, 0 skipped, 333 copied, 519MiB (84.7MiB/s), 10s
    7,898 scanned, 0 errors, 0 skipped, 366 copied, 969MiB (89.9MiB/s), 15s
    7,898 scanned, 0 errors, 0 skipped, 422 copied, 1.43GiB (99.8MiB/s), 20s
    7,898 scanned, 0 errors, 0 skipped, 1,100 copied, 1.69GiB (52.9MiB/s), 25s
    7,898 scanned, 0 errors, 0 skipped, 1,834 copied, 1.94GiB (50.4MiB/s), 30s
    7,898 scanned, 0 errors, 0 skipped, 1,906 copied, 2.43GiB (100MiB/s), 35s
    7,898 scanned, 0 errors, 0 skipped, 2,937 copied, 2.61GiB (36.6MiB/s), 40s
    7,898 scanned, 0 errors, 0 skipped, 2,969 copied, 3.09GiB (100.0MiB/s), 45s
    7,898 scanned, 0 errors, 0 skipped, 3,001 copied, 3.58GiB (100.0MiB/s), 50s
    7,898 scanned, 0 errors, 0 skipped, 3,298 copied, 4.01GiB (88.0MiB/s), 55s
    7,898 scanned, 0 errors, 0 skipped, 5,614 copied, 4.01GiB (679KiB/s), 1m0s
    7,898 scanned, 0 errors, 0 skipped, 7,879 copied, 4.02GiB (445KiB/s), 1m5s
    7,898 scanned, 0 errors, 0 skipped, 7,897 copied, 4.02GiB (63.2MiB/s), 1m5s
    备注 如果没有数据聚合,则使用存储创建一个新的数据聚合 `aggr create`命令。
  3. 同步源和目标上的文件。
    C:\xcp>xcp sync -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs
    10,796 scanned, 4,002 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 5s
    15,796 scanned, 8,038 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 10s
    15,796 scanned, 8,505 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 15s
    15,796 scanned, 8,707 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 20s
    15,796 scanned, 8,730 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 25s
    15,796 scanned, 8,749 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 30s
    15,796 scanned, 8,765 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 35s
    15,796 scanned, 8,786 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 40s
    15,796 scanned, 8,956 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 45s
    8 XCP v1.6 User Guide © 2020 NetApp, Inc. All rights reserved.
    Step Description
    15,796 scanned, 9,320 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 50s
    15,796 scanned, 9,339 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 55s
    15,796 scanned, 9,363 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m0s
    15,796 scanned, 10,019 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m5s
    15,796 scanned, 10,042 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m10s
    15,796 scanned, 10,059 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m15s
    15,796 scanned, 10,075 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m20s
    15,796 scanned, 10,091 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m25s
    15,796 scanned, 10,108 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m30s
    15,796 scanned, 10,929 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m35s
    15,796 scanned, 12,443 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m40s
    15,796 scanned, 13,963 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m45s
    15,796 scanned, 15,488 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m50s
    15,796 scanned, 15,796 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m51s
  4. 验证文件是否被正确复制。
    C:\xcp> xcp verify \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dir
    8 compared, 8 same, 0 different, 0 missing, 5s
    24 compared, 24 same, 0 different, 0 missing, 10s
    41 compared, 41 same, 0 different, 0 missing, 15s
    63 compared, 63 same, 0 different, 0 missing, 20s
    86 compared, 86 same, 0 different, 0 missing, 25s
    423 compared, 423 same, 0 different, 0 missing, 30s
    691 compared, 691 same, 0 different, 0 missing, 35s
    1,226 compared, 1,226 same, 0 different, 0 missing, 40s
    1,524 compared, 1,524 same, 0 different, 0 missing, 45s
    1,547 compared, 1,547 same, 0 different, 0 missing, 50s
    1,564 compared, 1,564 same, 0 different, 0 missing, 55s
    2,026 compared, 2,026 same, 0 different, 0 missing, 1m0s
    2,045 compared, 2,045 same, 0 different, 0 missing, 1m5s
    2,061 compared, 2,061 same, 0 different, 0 missing, 1m10s
    2,081 compared, 2,081 same, 0 different, 0 missing, 1m15s
    2,098 compared, 2,098 same, 0 different, 0 missing, 1m20s
    2,116 compared, 2,116 same, 0 different, 0 missing, 1m25s
    3,232 compared, 3,232 same, 0 different, 0 missing, 1m30s
    4,817 compared, 4,817 same, 0 different, 0 missing, 1m35s
    6,267 compared, 6,267 same, 0 different, 0 missing, 1m40s
    7,844 compared, 7,844 same, 0 different, 0 missing, 1m45s
    7,898 compared, 7,898 same, 0 different, 0 missing, 1m45s,cifs
