将数据从 7- 模式迁移到 ONTAP
本节详细介绍了将数据从 7- 模式 NetApp Data ONTAP 迁移到 ONTAP 的步骤。
将 7- 模式 NFSv3 存储过渡到 ONTAP 以获取 NFS 数据
本节介绍下表中的分步操作步骤,用于将源 7- 模式 NFSv3 导出过渡到 ONTAP 系统。
NetApp 假定源 7- 模式 NFSv3 卷已导出并挂载在客户端系统上,并且 XCP 已安装在 Linux 系统上。
验证目标 ONTAP 系统是否运行正常。
CLUSTER::> cluster show Node Health Eligibility --------------------- ------- ------------ CLUSTER-01 true true CLUSTER-02 true true 2 entries were displayed. CLUSTER::> node show Node Health Eligibility Uptime Model Owner Location --------- ------ ----------- ------------- ----------- -------- --------------- CLUSTER-01 true true 78 days 21:01 FAS8060 RTP CLUSTER-02 true true 78 days 20:50 FAS8060 RTP 2 entries were displayed. CLUSTER::> storage failover show Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------------------------- CLUSTER-01 CLUSTER-02 true Connected to CLUSTER-02 CLUSTER-02 CLUSTER-01 true Connected to CLUSTER-01 2 entries were displayed.
验证目标系统上是否至少存在一个非根聚合。聚合正常。
CLUSTER::> storage aggregate show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ aggr0 368.4GB 17.85GB 95% online 1 CLUSTER-01 raid_dp, normal aggr0_CLUSTER_02_0 368.4GB 17.85GB 95% online 1 CLUSTER-02 raid_dp, normal source 1.23TB 1.10TB 11% online 6 CLUSTER-01 raid_dp, normal 3 entries were displayed.
如果没有数据聚合,请使用
storage aggr create
命令创建一个新聚合。 -
在目标集群系统上创建 Storage Virtual Machine ( SVM )。
CLUSTER::> vserver create -vserver dest -rootvolume dest_root -aggregate poc -rootvolume-security-style mixed [Job 647] Job succeeded: Vserver creation completed Verify the security style and language settings of the source Verify that the SVM was successfully created. CLUSTER::> vserver show -vserver dest Vserver: dest Vserver Type: data Vserver Subtype: default Vserver UUID: 91f6d786-0063-11e5-b114-00a09853a969 Root Volume: dest_root Aggregate: poc NIS Domain: - Root Volume Security Style: mixed LDAP Client: - Default Volume Language Code: C.UTF-8 Snapshot Policy: default Comment: Quota Policy: default List of Aggregates Assigned: - Limit on Maximum Number of Volumes allowed: unlimited Vserver Admin State: running Vserver Operational State: running Vserver Operational State Stopped Reason: - Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp Disallowed Protocols: - Is Vserver with Infinite Volume: false QoS Policy Group: - Config Lock: false IPspace Name: Default
从目标 SVM 中删除 FCP , iSCSI , NDMP 和 CIDS 协议。
CLUSTER::> vserver remove-protocols -vserver dest -protocols fcp,iscsi,ndmp,cifs
验证此 SVM 是否支持 NFS 协议。
CLUSTER::> vserver show -vserver dest -fields allowed-protocols vserver allowed-protocols ------- ----------------- dest nfs
在目标 SVM 上创建新的读写数据卷。验证安全模式,语言设置和容量要求是否与源卷匹配。
CLUSTER::> vol create -vserver dest -volume dest_nfs -aggregate poc -size 150g -type RW -state online -security-style mixed [Job 648] Job succeeded: Successful
创建数据 LIF 以处理 NFS 客户端请求。
CLUSTER::> network interface create -vserver dest -lif dest_lif -address 10.61.73.115 -netmask 255.255.255.0 -role data -data-protocol nfs -home-node CLUSTER-01 -home-port e0l
验证是否已成功创建 LIF 。
CLUSTER::> network interface show -vserver dest Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- dest dest_lif up/up 10.61.73.113/24 CLUSTER-01 e0i true
如果需要,使用 SVM 创建静态路由。
CLUSTER::> network route create -vserver dest -destination 0.0.0.0/0 -gateway 192.168.100.111
验证是否已成功创建路由。
CLUSTER::> network route show -vserver source Vserver Destination Gateway Metric ------------------- --------------- --------------- ------ dest 0.0.0.0/0 10.61.73.1 20
在 SVM 命名空间中挂载目标 NFS 数据卷。
CLUSTER::> volume mount -vserver dest -volume dest_nfs -junction-path /dest_nfs -active true
验证是否已成功挂载此卷。
CLUSTER::> volume show -vserver dest -fields junction-path vserver volume junction-path ------- -------- ------------- dest dest_nfs /dest_nfs dest dest_root / 2 entries were displayed.
您也可以使用
volume create
命令指定卷挂载选项(接合路径)。 -
在目标 SVM 上启动 NFS 服务。
CLUSTER::> vserver nfs start -vserver dest
验证此服务是否已启动并正在运行。
CLUSTER::> vserver nfs status The NFS server is running on Vserver "dest". CLUSTER::> nfs show Vserver: dest General Access: true v3: enabled v4.0: disabled 4.1: disabled UDP: enabled TCP: enabled Default Windows User: - Default Windows Group: -
验证默认 NFS 导出策略是否已应用于目标 SVM 。
CLUSTER::> vserver export-policy show -vserver dest Vserver Policy Name --------------- ------------------- dest default
如果需要,为目标 SVM 创建新的自定义导出策略。
CLUSTER::> vserver export-policy create -vserver dest -policyname xcpexportpolicy
验证是否已成功创建新的自定义导出策略。
CLUSTER::> vserver export-policy show -vserver dest Vserver Policy Name --------------- ------------------- dest default dest xcpexportpolicy 2 entries were displayed.
修改导出策略规则以允许访问 NFS 客户端。
CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0 Verify the policy rules have modified CLUSTER::> export-policy rule show -instance Vserver: dest Policy Name: xcpexportpolicy Rule Index: 1 Access Protocol: nfs3 Client Match Hostname, IP Address, Netgroup, or Domain: 0.0.0.0/0 RO Access Rule: none RW Access Rule: none User ID To Which Anonymous Users Are Mapped: 65534 Superuser Security Types: none Honor SetUID Bits in SETATTR: true Allow Creation of Devices: true
验证是否允许客户端访问卷。
CLUSTER::> export-policy check-access -vserver dest -volume dest_nfs -client-ip 10.61.82.215 -authentication-method none -protocol nfs3 -access-type read-write Policy Policy Rule Path Policy Owner Owner Type Index Access ----------------------------- ---------- --------- ---------- ------ ---------- / xcpexportpolicy dest_root volume 1 read /dest_nfs xcpexportpolicy dest_nfs volume 1 read-write 2 entries were displayed.
连接到 Linux NFS 服务器。为 NFS 导出的卷创建挂载点。
[root@localhost /]# cd /mnt [root@localhost mnt]# mkdir dest
在此挂载点挂载目标 NFSv3 导出的卷。
NFSv3 卷应导出,但不一定由 NFS 服务器挂载。如果可以挂载这些卷,则 XCP Linux 主机客户端会挂载这些卷。 [root@localhost mnt]# mount -t nfs 10.61.73.115:/dest_nfs /mnt/dest
验证是否已成功创建挂载点。
[root@ localhost /]# mount | grep nfs 10.61.73.115:/dest_nfs on /mnt/dest type nfs (rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=10.61.82.215,mountvers=3,mountport=4046,mountproto=udp,local_lock=none,addr=10.61.73.115)
在 NFS 导出的挂载点上创建一个测试文件,以启用读写访问。
[root@localhost dest]# touch test.txt Verify the file is created [root@localhost dest]# ls -l total 0 -rw-r--r-- 1 root bin 0 Jun 2 03:16 test.txt
读写测试完成后,从目标 NFS 挂载点删除该文件。 -
连接到安装了 XCP 的 Linux 客户端系统。浏览到 XCP 安装路径。
[root@localhost ~]# cd /linux/ [root@localhost linux]#
在 XCP Linux 客户端主机系统上运行
XCP show
命令,查询源 7- 模式 NFSv3 导出。[root@localhost]#./xcp show 10.61.82.215 == NFS Exports == Mounts Errors Server 4 0 10.61.82.215 Space Files Space Files Free Free Used Used Export 23.7 GiB 778,134 356 KiB 96 10.61.82.215:/vol/nfsvol1 17.5 GiB 622,463 1.46 GiB 117 10.61.82.215:/vol/nfsvol 328 GiB 10.8M 2.86 GiB 7,904 10.61.82.215:/vol/vol0/home 328 GiB 10.8M 2.86 GiB 7,904 10.61.82.215:/vol/vol0 == Attributes of NFS Exports == drwxr-xr-x --- root wheel 4KiB 4KiB 2d21h 10.61.82.215:/vol/nfsvol1 drwxr-xr-x --- root wheel 4KiB 4KiB 2d21h 10.61.82.215:/vol/nfsvol drwxrwxrwx --t root wheel 4KiB 4KiB 9d22h 10.61.82.215:/vol/vol0/home drwxr-xr-x --- root wheel 4KiB 4KiB 4d0h 10.61.82.215:/vol/vol0 3.89 KiB in (5.70 KiB/s), 7.96 KiB out (11.7 KiB/s), 0s.
扫描源 NFSv3 导出的路径并打印其文件结构的统计信息。
NetApp 建议在 XCP
scan
,copy
和sync
操作期间将源 NFSv3 导出置于只读模式。[root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol nfsvol nfsvol/n5000-uk9.5.2.1.N1.1.bin nfsvol/821_q_image.tgz nfsvol/822RC2_q_image.tgz nfsvol/NX5010_12_node_RCF_v1.3.txt nfsvol/n5000-uk9-kickstart.5.2.1.N1.1.bin nfsvol/NetApp_CN1610_1.1.0.5.stk nfsvol/glibc-common-2.7-2.x86_64.rpm nfsvol/glibc-2.7-2.x86_64.rpm nfsvol/rhel-server-5.6-x86_64-dvd.iso.filepart nfsvol/xcp nfsvol/xcp_source nfsvol/catalog 23 scanned, 7.79 KiB in (5.52 KiB/s), 1.51 KiB out (1.07 KiB/s), 1s.
将源 7- 模式 NFSv3 导出复制到目标 ONTAP 系统上的 NFSv3 导出。
[root@localhost /]# ./xcp copy 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs 44 scanned, 39 copied, 264 MiB in (51.9 MiB/s), 262 MiB out (51.5 MiB/s), 5s 44 scanned, 39 copied, 481 MiB in (43.3 MiB/s), 479 MiB out (43.4 MiB/s), 10s 44 scanned, 40 copied, 748 MiB in (51.2 MiB/s), 747 MiB out (51.3 MiB/s), 16s 44 scanned, 40 copied, 1.00 GiB in (55.9 MiB/s), 1.00 GiB out (55.9 MiB/s), 21s 44 scanned, 40 copied, 1.21 GiB in (42.8 MiB/s), 1.21 GiB out (42.8 MiB/s), 26s Sending statistics... 44 scanned, 43 copied, 1.46 GiB in (47.6 MiB/s), 1.45 GiB out (47.6 MiB/s), 31s.
复制完成后,验证源和目标 NFSv3 导出是否具有相同的数据。运行
XCP verify
命令。[root@localhost /]# ./xcp verify 10.61.82.215:/vol/nfsvol 10.61.73.115:/dest_nfs 44 scanned, 44 found, 28 compared, 27 same data, 2.41 GiB in (98.4 MiB/s), 6.25 MiB out (255 KiB/s), 26s 44 scanned, 44 found, 30 compared, 29 same data, 2.88 GiB in (96.4 MiB/s), 7.46 MiB out (249 KiB/s), 31s 44 scanned, 100% found (43 have data), 43 compared, 100% verified (data, attrs, mods), 2.90 GiB in (92.6 MiB/s), 7.53 MiB out (240 KiB/s), 32s.
如果
XCP verify
发现源数据与目标数据之间存在差异,则摘要中会报告错误no such file or directory
。要修复此问题描述,请运行XCP sync
命令将源更改复制到目标。 -
在转换之前和期间,再次运行
verify
。如果源包含新数据或更新的数据,请执行增量更新。运行XCP sync
命令。For this operation, the previous copy index name or number is required. [root@localhost /]# ./xcp sync -id 3 Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs1'} 64 reviewed, 64 checked at source, 6 changes, 6 modifications, 51.7 KiB in (62.5 KiB/s), 22.7 KiB out (27.5 KiB/s), 0s. xcp: sync '3': Starting search pass for 1 modified directory... xcp: sync '3': Found 6 indexed files in the 1 changed directory xcp: sync '3': Rereading the 1 modified directory to find what's new... xcp: sync '3': Deep scanning the 1 directory that changed... 11 scanned, 11 copied, 12.6KiB in (6.19KiBps), 9.50 KiB out (4.66KiBps), 2s.
要恢复先前中断的复制操作,请运行
XCP resume
命令。[root@localhost /]# ./xcp resume -id 4 Index: {source: '10.61.82.215:/vol/nfsvol', target: '10.61.73.115:/dest_nfs7'} xcp: resume '4': WARNING: Incomplete index. xcp: resume '4': Found 18 completed directories and 1 in progress 106 reviewed, 24.2 KiB in (30.3 KiB/s), 7.23 KiB out (9.06 KiB/s), 0s. xcp: resume '4': Starting second pass for the in-progress directory... xcp: resume '4': Found 3 indexed directories and 0 indexed files in the 1 in-progress directory xcp: resume '4': In progress dirs: unindexed 1, indexed 0 xcp: resume '4': Resuming the 1 in-progress directory... 20 scanned, 7 copied, 205 MiB in (39.6 MiB/s), 205 MiB out (39.6 MiB/s), 5s 20 scanned, 14 copied, 425 MiB in (42.1 MiB/s), 423 MiB out (41.8 MiB/s), 11s 20 scanned, 14 copied, 540 MiB in (23.0 MiB/s), 538 MiB out (23.0 MiB/s), 16s 20 scanned, 14 copied, 721 MiB in (35.6 MiB/s), 720 MiB out (35.6 MiB/s), 21s 20 scanned, 15 copied, 835 MiB in (22.7 MiB/s), 833 MiB out (22.7 MiB/s), 26s 20 scanned, 16 copied, 1007 MiB in (34.3 MiB/s), 1005 MiB out (34.3 MiB/s), 31s 20 scanned, 17 copied, 1.15 GiB in (33.9 MiB/s), 1.15 GiB out (33.9 MiB/s), 36s 20 scanned, 17 copied, 1.27 GiB in (25.5 MiB/s), 1.27 GiB out (25.5 MiB/s), 41s 20 scanned, 17 copied, 1.45 GiB in (36.1 MiB/s), 1.45 GiB out (36.1 MiB/s), 46s 20 scanned, 17 copied, 1.69 GiB in (48.7 MiB/s), 1.69 GiB out (48.7 MiB/s), 51s Sending statistics... 20 scanned, 20 copied, 21 indexed, 1.77 GiB in (33.5 MiB/s), 1.77 GiB out (33.4 MiB/s), 54s.
在
re恢复
完成复制文件后,再次运行ve执行
以使源存储和目标存储具有相同的数据。 -
NFSv3 客户端主机需要卸载从 7- 模式存储配置的源 NFSv3 导出,并从 ONTAP 挂载目标 NFSv3 导出。转换需要中断。
将 7- 模式卷 Snapshot 副本过渡到 ONTAP
本节介绍用于将源 7- 模式卷 NetApp Snapshot 副本过渡到 ONTAP 的操作步骤。
NetApp 假定源 7- 模式卷已导出并挂载在客户端系统上,并且 XCP 已安装在 Linux 系统上。Snapshot 副本是卷的时间点映像,用于记录自上次 Snapshot 副本以来的增量更改。使用 ` -snap` 选项并将 7- 模式系统作为源。 |
警告: * 保留基本 Snapshot 副本。基线副本完成后,请勿删除基线 Snapshot 副本。要执行进一步的同步操作,需要使用基本 Snapshot 副本。
如果没有数据聚合,请使用
storage aggr create
命令创建一个新聚合。 -
在目标集群系统上创建 SVM 。
从目标 SVM 中删除 FCP , iSCSI , NDMP 和 CIFS 协议。
CLUSTER::> vserver remove-protocols -vserver dest -protocols fcp,iscsi,ndmp,cifs Verify that NFS is the allowed protocol for this SVM. CLUSTER::> vserver show -vserver dest -fields allowed-protocols vserver allowed-protocols ------- ----------------- dest nfs
验证是否已成功创建 LIF 。
如果需要,使用 SVM 创建静态路由。
验证是否已成功创建路由。
验证是否已成功挂载此卷。
您也可以使用
volume create
命令指定卷挂载选项(接合路径)。 -
在目标 SVM 上启动 NFS 服务。
验证此服务是否已启动并正在运行。
验证默认 NFS 导出策略是否应用于目标 SVM 。
验证是否已成功创建新的自定义导出策略。
修改导出策略规则以允许访问目标系统上的 NFS 客户端。
验证客户端是否有权访问目标卷。
验证是否已成功创建挂载点。
XCP show
NetApp 建议在
XCP scan
,copy
和sync
操作期间将源 NFSv3 导出置于只读模式。在sync
操作中,您必须使用相应的值传递 ` -snap` 选项。[root@localhost /]# ./xcp scan 10.61.82.215:/vol/nfsvol/.snapshot/snap1 nfsvol nfsvol/n5000-uk9.5.2.1.N1.1.bin nfsvol/821_q_image.tgz nfsvol/822RC2_q_image.tgz nfsvol/NX5010_12_node_RCF_v1.3.txt nfsvol/n5000-uk9-kickstart.5.2.1.N1.1.bin nfsvol/catalog 23 scanned, 7.79 KiB in (5.52 KiB/s), 1.51 KiB out (1.07 KiB/s), 1s. [root@scspr1202780001 vol_acl4]# ./xcp sync -id 7msnap1 -snap 10.236.66.199:/vol/nfsvol/.snapshot/snap10 (show scan and sync)
将源 7- 模式 NFSv3 快照(基本)复制到目标 ONTAP 系统上的 NFSv3 导出。
[root@localhost /]# /xcp copy 10.61.82.215:/vol/nfsvol/.snapshot/snap1 10.61.73.115:/dest_nfs 44 scanned, 39 copied, 264 MiB in (51.9 MiB/s), 262 MiB out (51.5 MiB/s), 5s 44 scanned, 39 copied, 481 MiB in (43.3 MiB/s), 479 MiB out (43.4 MiB/s), 10s 44 scanned, 40 copied, 748 MiB in (51.2 MiB/s), 747 MiB out (51.3 MiB/s), 16s 44 scanned, 40 copied, 1.00 GiB in (55.9 MiB/s), 1.00 GiB out (55.9 MiB/s), 21s 44 scanned, 40 copied, 1.21 GiB in (42.8 MiB/s), 1.21 GiB out (42.8 MiB/s), 26s Sending statistics... 44 scanned, 43 copied, 1.46 GiB in (47.6 MiB/s), 1.45 GiB out (47.6 MiB/s), 31s.
保留此基本快照以执行进一步的同步操作。 -
XCP verify
如果
verify
发现源数据与目标数据之间的差异,则摘要中会报告错误no such file or directory `。要修复此问题描述,请运行 `XCP sync
命令将源更改复制到目标。 -
在转换之前和期间,再次运行
verify
。如果源包含新数据或更新的数据,请执行增量更新。如果存在增量更改,请为这些更改创建一个新的 Snapshot 副本,并使用 ` -snap` 选项传递该快照路径以执行同步操作。使用 ` -snap` 选项和快照路径运行
XCP sync
命令。
[root@localhost /]# ./xcp sync -id 3 Index: {source: '10.61.82.215:/vol/nfsvol/.snapshot/snap1', target: '10.61.73.115:/dest_nfs1'} 64 reviewed, 64 checked at source, 6 changes, 6 modifications, 51.7 KiB in (62.5 KiB/s), 22.7 KiB out (27.5 KiB/s), 0s. xcp: sync '3': Starting search pass for 1 modified directory... xcp: sync '3': Found 6 indexed files in the 1 changed directory xcp: sync '3': Rereading the 1 modified directory to find what's new... xcp: sync '3': Deep scanning the 1 directory that changed... 11 scanned, 11 copied, 12.6 KiB in (6.19 KiB/s), 9.50 KiB out (4.66 KiB/s), 2s..
对于此操作,需要使用基本快照。 -
要恢复先前中断的复制操作,请运行
XCP resume
命令。[root@scspr1202780001 534h_dest_vol]# ./xcp resume -id 3 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxxxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 xcp: Index: {source: '10.61.82.215:/vol/nfsvol',/.snapshot/snap1, target: 10.237.160.55:/dest_vol} xcp: resume '7msnap_res1': Reviewing the incomplete index... xcp: diff '7msnap_res1': Found 143 completed directories and 230 in progress 39,688 reviewed, 1.28 MiB in (1.84 MiB/s), 13.3 KiB out (19.1 KiB/s), 0s. xcp: resume '7msnap_res1': Starting second pass for the in-progress directories... xcp: resume '7msnap_res1': Resuming the in-progress directories... xcp: resume '7msnap_res1': Resumed command: copy {-newid: u'7msnap_res1'} xcp: resume '7msnap_res1': Current options: {-id: '7msnap_res1'} xcp: resume '7msnap_res1': Merged options: {-id: '7msnap_res1', -newid: u'7msnap_res1'} xcp: resume '7msnap_res1': Values marked with a * include operations before resume 68,848 scanned*, 54,651 copied*, 39,688 indexed*, 35.6 MiB in (7.04 MiB/s), 28.1 MiB out (5.57 MiB/s), 5s
NFSv3 客户端主机必须卸载从 7- 模式存储配置的源 NFSv3 导出,并从 ONTAP 挂载目标 NFSv3 导出。此转换需要中断。
将 ACLv4 从 NetApp 7- 模式迁移到 NetApp 存储系统
本节介绍将源 NFSv4 导出过渡到 ONTAP 系统的分步操作步骤。
NetApp 假定源 NFSv4 卷已导出并挂载在客户端系统上,并且 XCP 已安装在 Linux 系统上。源系统应为支持 ACL 的 NetApp 7- 模式系统。ACL 迁移仅支持从 NetApp 迁移到 NetApp 。要复制名称中包含特殊字符的文件,请确保源和目标支持 UTF-8 编码语言。 |
将源 NFSv4 导出迁移到 ONTAP 的前提条件
在将源 NFSv4 导出迁移到 ONTAP 之前,必须满足以下前提条件:
目标系统必须配置 NFSv4 。
NFSv4 源和目标必须挂载在 XCP 主机上。选择 NFS v4.0 以匹配源存储和目标存储,并验证源系统和目标系统上是否已启用 ACL 。
XCP 要求在 XCP 主机上挂载源 / 目标路径以进行 ACL 处理。在以下示例中,
vol1 ( 10.63.5.56 : /vol1 )
已挂载在 ` /mnt/vol1` 路径上:
[root@localhost ~]# df -h Filesystem Size Used Avail Use% Mounted on 10.63.5.56:/vol1 973M 4.2M 969M 1% /mnt/vol1 [root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/ XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029 drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1 rw-r--r-- --- root root 4 0 23h42m vol1/DIR1/FILE drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11 drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1 rw-r--r-- --- root root 4 0 23h42m vol1/DIR1/DIR11/FILE drwxr-xr-x --- root root 4KiB 4KiB 23h42m vol1/DIR1/DIR11/DIR2 rw-r--r-- --- root root 4 0 23h42m vol1/DIR1/DIR11/DIR2/FILE drwxr-xr-x --- root root 4KiB 4KiB 17m43s vol1/DIR1/DIR11/DIR2/DIR22 8 scanned, 8 getacls, 1 v3perm, 7 acls, 3.80 KiB in (3.86 KiB/s), 1.21 KiB out (1.23 KiB/s), 0s.
子目录选项
使用子目录的两个选项如下:
要使 XCP 在子目录 ` ( /vol1/dir1/DIR11` )上运行,请在 XCP 主机上挂载完整路径(
10.63.5.56 : /vol1/dir1/DIR11
)。如果未挂载完整路径, XCP 将报告以下错误:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1/DIR1/DIR11 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029 xcp: ERROR: For xcp to process ACLs, please mount 10.63.5.56:/vol1/DIR1/DIR11 using the OS nfs4 client.
使用子目录语法(
mount :子目录 /qtree/.snapshot
),如以下示例所示:
[root@localhost ~]# ./xcp scan -l -acl4 10.63.5.56:/vol1:/DIR1/DIR11 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Sun Mar 31 00:00:00 2029 drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11 rw-r--r-- --- root root 4 0 23h51m DIR11/DIR2/FILE drwxr-xr-x --- root root 4KiB 4KiB 26m9s DIR11/DIR2/DIR22 rw-r--r-- --- root root 4 0 23h51m DIR11/FILE drwxr-xr-x --- root root 4KiB 4KiB 23h51m DIR11/DIR2 5 scanned, 5 getacls, 5 acls, 2.04 KiB in (3.22 KiB/s), 540 out (850/s), 0s.
要将 ACLv4 从 NetApp 7- 模式迁移到 NetApp 存储系统,请完成以下步骤。
如果没有数据聚合,请使用
storage aggr create
命令创建一个新聚合。 -
在目标集群系统上创建 SVM 。
验证是否已成功创建 SVM 。
验证是否已成功创建 LIF 。
如果需要,使用 SVM 创建静态路由。
验证是否已成功创建路由。
验证是否已成功挂载此卷。
您也可以使用
volume create
命令指定卷挂载选项(接合路径)。 -
在目标 SVM 上启动 NFS 服务。
验证此服务是否已启动并正在运行。
CLUSTER::> vserver nfs status The NFS server is running on Vserver "dest". CLUSTER::> nfs show Vserver: dest General Access: true v3: enabled v4.0: enabled 4.1: disabled UDP: enabled TCP: enabled Default Windows User: - Default Windows Group: -
检查默认 NFS 导出策略是否应用于目标 SVM 。
验证是否已成功创建新的自定义导出策略。
验证是否已修改策略规则。
验证是否允许客户端访问卷。
在此挂载点挂载目标 NFSv4 导出的卷。
NFSv4 卷应导出,但不一定由 NFS 服务器挂载。如果可以挂载这些卷,则 XCP Linux 主机客户端会挂载这些卷。 [root@localhost mnt]# mount -t nfs4 10.63.5.56:/vol1 /mnt/vol1
验证是否已成功创建挂载点。
[root@localhost mnt]# mount | grep nfs 10.63.5.56:/vol1 on /mnt/vol1 type nfs4 (rw,relatime,vers=4.0,rsize=65536,wsize=65536,namlen=255,hard,proto=tcp,timeo=600, retrans=2,sec=sys,clientaddr=10.234.152.84,local_lock=none,addr=10.63.5.56)
验证是否已创建文件。
XCP show
命令,查询源 NFSv4 导出。root@localhost]# ./xcp show 10.63.5.56 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 getting pmap dump from 10.63.5.56 port 111... getting export list from 10.63.5.56... sending 6 mounts and 24 nfs requests to 10.63.5.56... == RPC Services == '10.63.5.56': UDP rpc services: MNT v1/2/3, NFS v3, NLM v4, PMAP v2/3/4, STATUS v1 '10.63.5.56': TCP rpc services: MNT v1/2/3, NFS v3/4, NLM v4, PMAP v2/3/4, STATUS v1 == NFS Exports == Mounts Errors Server 6 0 10.63.5.56 Space Files Space Files Free Free Used Used Export 94.7 MiB 19,883 324 KiB 107 10.63.5.56:/ 971 MiB 31,023 2.19 MiB 99 10.63.5.56:/vol2 970 MiB 31,024 2.83 MiB 98 10.63.5.56:/vol1 9.33 GiB 310,697 172 MiB 590 10.63.5.56:/vol_005 43.3 GiB 1.10M 4.17 GiB 1.00M 10.63.5.56:/vol3 36.4 GiB 1.10M 11.1 GiB 1.00M 10.63.5.56:/vol4 == Attributes of NFS Exports == drwxr-xr-x --- root root 4KiB 4KiB 6d2h 10.63.5.56:/ drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol2 drwxr-xr-x --- root root 4KiB 4KiB 3d2h 10.63.5.56:/vol1 drwxr-xr-x --- root root 4KiB 4KiB 9d2h 10.63.5.56:/vol_005 drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol3 drwxr-xr-x --- root root 4KiB 4KiB 9d4h 10.63.5.56:/vol4 6.09 KiB in (9.19 KiB/s), 12.2 KiB out (18.3 KiB/s), 0s.
扫描源 NFSv4 导出的路径并打印其文件结构的统计信息。
NetApp 建议在
XCP scan
,copy
和sync
操作期间将源 NFSv4 导出置于只读模式。[root@localhost]# ./xcp scan -acl4 10.63.5.56:/vol1 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 vol1 vol1/test/f1 vol1/test 3 scanned, 3 getacls, 3 v3perms, 1.59 KiB in (1.72 KiB/s), 696 out (753/s), 0s.
将源 NFSv4 导出复制到目标 ONTAP 系统上的 NFSv4 导出。
[root@localhost]# ./xcp copy -acl4 -newid id1 10.63.5.56:/vol1 10.63.5.56:/vol2 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 3 scanned, 2 copied, 3 indexed, 3 getacls, 3 v3perms, 1 setacl, 14.7 KiB in (11.7 KiB/s), 61 KiB out (48.4 KiB/s), 1s..
完成
copy
后,验证源和目标 NFSv4 导出是否具有相同的数据。运行XCP verify
命令。[root@localhost]# ./xcp verify -acl4 -noid 10.63.5.56:/vol1 10.63.5.56:/vol2 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 3 scanned, 100% found (0 have data), 100% verified (data, attrs, mods, acls), 6 getacls, 6 v3perms, 2.90 KiB in (4.16 KiB/s), 2.94 KiB out (4.22 KiB/s), 0s.
如果
verify
命令将源更改复制到目标。 -
在转换之前和期间,再次运行
verify
命令。[root@ root@localhost]# ./xcp sync -id id1 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 xcp: Index: {source: 10.63.5.56:/vol1, target: 10.63.5.56:/vol2} 3 reviewed, 3 checked at source, no changes, 3 reindexed, 25.6 KiB in (32.3 KiB/s), 23.3 KiB out (29.5 KiB/s), 0s.
对于此操作,需要使用先前的副本索引名称或编号。 -
要恢复先前中断的
copy
操作,请运行XCP resume
命令。[root@localhost]# ./xcp resume -id id1 XCP <version>; (c) 2020 NetApp, Inc.; Licensed to xxx [NetApp Inc] until Mon Dec 31 00:00:00 2029 xcp: Index: {source: 10.63.5.56:/vol3, target: 10.63.5.56:/vol4} xcp: resume 'id1': Reviewing the incomplete index... xcp: diff 'id1': Found 0 completed directories and 8 in progress 39,899 reviewed, 1.64 MiB in (1.03 MiB/s), 14.6 KiB out (9.23 KiB/s), 1s. xcp: resume 'id1': Starting second pass for the in-progress directories... xcp: resume 'id1': Resuming the in-progress directories... xcp: resume 'id1': Resumed command: copy {-acl4: True} xcp: resume 'id1': Current options: {-id: 'id1'} xcp: resume 'id1': Merged options: {-acl4: True, -id: 'id1'} xcp: resume 'id1': Values marked with a * include operations before resume 86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (2.60 MiB/s), 78.4 KiB out (15.6 KiB/s), 5s 86,404 scanned, 39,912 copied, 39,899 indexed, 13.0 MiB in (0/s), 78.4 KiB out (0/s), 10s 1.00M scanned, 100% found (1M have data), 1M compared, 100% verified (data, attrs, mods, acls), 2.00M getacls, 202 v3perms, 1.00M same acls, 2.56 GiB in (2.76 MiB/s), 485 MiB out (524 KiB/s), 15m48s.
在
re恢复
完成复制文件后,再次运行ve执行
以使源存储和目标存储具有相同的数据。
将 7- 模式 SMB 存储过渡到 ONTAP 以获取 CIFS 数据
本节介绍将源 7- 模式 SMB 共享过渡到 ONTAP 系统的分步操作步骤。
NetApp 假定 7- 模式和 ONTAP 系统已获得 SMB 许可。此时将创建目标 SVM ,导出源和目标 SMB 共享,并安装 XCP 并获得许可。 |
扫描 SMB 共享中的文件和目录。
C:\xcp>xcp scan -stats \\10.61.77.189\performance_SMB_home_dirs XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 == Maximum Values == Size Depth Namelen Dirsize 15.6MiB 2 8 200 == Average Values == Size Depth Namelen Dirsize 540KiB 2 7 81 == Top File Extensions == .txt .tmp 5601 2200 == Number of files == empty <8KiB 8-64KiB 64KiB-1MiB 1-10MiB 10-100MiB >100MiB 46 6301 700 302 200 252 == Space used == empty <8KiB 8-64KiB 64KiB-1MiB 1-10MiB 10-100MiB >100MiB 0 6.80MiB 8.04MiB 120MiB 251MiB 3.64GiB 0 == Directory entries == empty 1-10 10-100 100-1K 1K-10K >10k 18 1 77 1 == Depth == 0-5 6-10 11-15 16-20 21-100 >100 7898 == Modified == >1 year >1 month 1-31 days 1-24 hrs <1 hour <15 mins future 2167 56 322 5353 == Created == >1 year >1 month 1-31 days 1-24 hrs <1 hour <15 mins future 2171 54 373 5300 Total count: 7898 Directories: 97 Regular files: 7801 Symbolic links: Junctions: Special files: Total space for regular files: 4.02GiB Total space for directories: 0 Total space used: 4.02GiB 7,898 scanned, 0 errors, 0s
将文件(带或不带 ACL )从源 SMB 共享复制到目标 SMB 共享。以下示例显示了一个具有 ACL 的副本。
C:\xcp>xcp copy -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 7,898 scanned, 0 errors, 0 skipped, 184 copied, 96.1MiB (19.2MiB/s), 5s 7,898 scanned, 0 errors, 0 skipped, 333 copied, 519MiB (84.7MiB/s), 10s 7,898 scanned, 0 errors, 0 skipped, 366 copied, 969MiB (89.9MiB/s), 15s 7,898 scanned, 0 errors, 0 skipped, 422 copied, 1.43GiB (99.8MiB/s), 20s 7,898 scanned, 0 errors, 0 skipped, 1,100 copied, 1.69GiB (52.9MiB/s), 25s 7,898 scanned, 0 errors, 0 skipped, 1,834 copied, 1.94GiB (50.4MiB/s), 30s 7,898 scanned, 0 errors, 0 skipped, 1,906 copied, 2.43GiB (100MiB/s), 35s 7,898 scanned, 0 errors, 0 skipped, 2,937 copied, 2.61GiB (36.6MiB/s), 40s 7,898 scanned, 0 errors, 0 skipped, 2,969 copied, 3.09GiB (100.0MiB/s), 45s 7,898 scanned, 0 errors, 0 skipped, 3,001 copied, 3.58GiB (100.0MiB/s), 50s 7,898 scanned, 0 errors, 0 skipped, 3,298 copied, 4.01GiB (88.0MiB/s), 55s 7,898 scanned, 0 errors, 0 skipped, 5,614 copied, 4.01GiB (679KiB/s), 1m0s 7,898 scanned, 0 errors, 0 skipped, 7,879 copied, 4.02GiB (445KiB/s), 1m5s 7,898 scanned, 0 errors, 0 skipped, 7,897 copied, 4.02GiB (63.2MiB/s), 1m5s
如果没有数据聚合,请使用 storage aggr create
命令创建一个新聚合。 -
同步源和目标上的文件。
C:\xcp>xcp sync -acl -fallback-user "DOMAIN\gabi" -fallback-group "DOMAIN\Group" \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dirs XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 10,796 scanned, 4,002 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 5s 15,796 scanned, 8,038 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 10s 15,796 scanned, 8,505 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 15s 15,796 scanned, 8,707 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 20s 15,796 scanned, 8,730 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 25s 15,796 scanned, 8,749 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 30s 15,796 scanned, 8,765 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 35s 15,796 scanned, 8,786 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 40s 15,796 scanned, 8,956 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 45s 8 XCP v1.6 User Guide © 2020 NetApp, Inc. All rights reserved. Step Description 15,796 scanned, 9,320 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 50s 15,796 scanned, 9,339 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 55s 15,796 scanned, 9,363 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m0s 15,796 scanned, 10,019 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m5s 15,796 scanned, 10,042 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m10s 15,796 scanned, 10,059 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m15s 15,796 scanned, 10,075 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m20s 15,796 scanned, 10,091 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m25s 15,796 scanned, 10,108 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m30s 15,796 scanned, 10,929 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m35s 15,796 scanned, 12,443 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m40s 15,796 scanned, 13,963 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m45s 15,796 scanned, 15,488 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m50s 15,796 scanned, 15,796 compared, 0 errors, 0 skipped, 0 copied, 0 removed, 1m51s
验证是否已正确复制这些文件。
C:\xcp> xcp verify \\10.61.77.189\performance_SMB_home_dirs \\10.61.77.56\performance_SMB_home_dir XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to xxxx xxxx[NetApp Inc] until Mon Dec 31 00:00:00 2029 8 compared, 8 same, 0 different, 0 missing, 5s 24 compared, 24 same, 0 different, 0 missing, 10s 41 compared, 41 same, 0 different, 0 missing, 15s 63 compared, 63 same, 0 different, 0 missing, 20s 86 compared, 86 same, 0 different, 0 missing, 25s 423 compared, 423 same, 0 different, 0 missing, 30s 691 compared, 691 same, 0 different, 0 missing, 35s 1,226 compared, 1,226 same, 0 different, 0 missing, 40s 1,524 compared, 1,524 same, 0 different, 0 missing, 45s 1,547 compared, 1,547 same, 0 different, 0 missing, 50s 1,564 compared, 1,564 same, 0 different, 0 missing, 55s 2,026 compared, 2,026 same, 0 different, 0 missing, 1m0s 2,045 compared, 2,045 same, 0 different, 0 missing, 1m5s 2,061 compared, 2,061 same, 0 different, 0 missing, 1m10s 2,081 compared, 2,081 same, 0 different, 0 missing, 1m15s 2,098 compared, 2,098 same, 0 different, 0 missing, 1m20s 2,116 compared, 2,116 same, 0 different, 0 missing, 1m25s 3,232 compared, 3,232 same, 0 different, 0 missing, 1m30s 4,817 compared, 4,817 same, 0 different, 0 missing, 1m35s 6,267 compared, 6,267 same, 0 different, 0 missing, 1m40s 7,844 compared, 7,844 same, 0 different, 0 missing, 1m45s 7,898 compared, 7,898 same, 0 different, 0 missing, 1m45s,cifs
