ONTAP SAN Host Utilities
适用于 ONTAP 存储配置的 AIX Host Utilities 命令
贡献者 netapp-pcarriga
您可以使用"AIX主机实用程序"示例命令参考使用"主机实用程序"工具对NetApp存储配置进行端到端验证。
列出映射到主机的所有主机启动程序
您可以检索映射到主机的主机启动程序列表。
sanlun fcp show adapter -v
8.0
显示 AIX Host Utilities 8.0 的示例
adapter name:      fcs4
WWPN:              100000109bf606a8
WWNN:              200000109bf606a8
driver name:       /usr/lib/drivers/pci/emfcdd
model:             df1000e31410150
model description: FC Adapter
serial number:     Y050HY22L002
hardware version:  Not Available
driver version:    7.2.5.201
firmware version:  00014000000057400007
Number of ports:   1
port type:         Fabric
port state:        Operational
supported speed:   32 GBit/sec
negotiated speed:  32 GBit/sec
OS device name:    fcs4
adapter name:      fcs5
WWPN:              100000109bf606a9
WWNN:              200000109bf606a9
Number of ports:   1
port type:         Fabric
OS device name:    fcs5
bash-3.2#
7.0 和 6.1
显示 AIX Host Utilities 7.0 和 6.1 的示例
bash-3.2# sanlun fcp show adapter -v
adapter name: fcs0
WWPN: 100000109b22e143
WWNN: 200000109b22e143
serial number: YA50HY79S117
driver version: 7.2.5.0
firmware version: 00012000040025700027
Number of ports: 1
port type: Fabric
supported speed: 16 GBit/sec
negotiated speed: Unknown
OS device name: fcs0
adapter name: fcs1
WWPN: 100000109b22e144
WWNN: 200000109b22e144
Number of ports: 1
port type: Fabric
OS device name: fcs1
bash-3.2#
列出映射到主机的所有 LUN
您可以检索映射到主机的所有LUN的列表。
sanlun lun show -p -v all
8.0
LUN: 88
LUN Size: 15g
Host Device: hdisk9
Mode: C
Multipath Provider: AIX Native
Multipathing Algorithm: round_robin
host    vserver  AIX   AIX MPIO
path    path     MPIO  host      vserver      path
state   type     path  adapter   LIF          priority
up     primary   path0   fcs0    fc_aix_1     1
up     primary   path1   fcs1    fc_aix_2     1
up     secondary path2   fcs0    fc_aix_3     1
up     secondary path3   fcs1    fc_aix_4     1
7.0 和 6.1
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun
LUN: 88
LUN Size: 15g
Host Device: hdisk9
Mode: C
列出从给定 SVM 映射到主机的所有 LUN
您可以从指定的SVM检索映射到主机的所有LUN的列表。
sanlun lun show -p -v sanboot_unix
8.0
ONTAP Path: sanboot_unix:/vol/aix_205p2_boot_0/boot_205p2_lun
LUN: 0
LUN Size: 80.0g
Host Device: hdisk85
Mode: C
up      primary    path0 fcs0    sanboot_1   1
up      primary    path1 fcs1    sanboot_2   1
up      secondary  path2 fcs0    sanboot_3   1
up      secondary  path3 fcs1    sanboot_4   1
7.0 和 6.1
LUN: 0
LUN Size: 80.0g
Mode: C
列出映射到主机的给定 LUN 的所有属性
您可以检索映射到主机的指定LUN的所有属性的列表。
sanlun lun show -p -v vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun
8.0
LUN: 88
LUN Size: 15g
Host Device: hdisk9
Mode: C
7.0 和 6.1
LUN: 88
LUN Size: 15g
Host Device: hdisk9
Mode: C
按主机设备文件名列出ONTAP LUN属性
您可以通过指定主机设备文件名来检索ONTAP LUN属性列表。
sanlun lun show -d /dev/hdisk1
8.0
controller(7mode)/
device host lun
vserver(Cmode)     lun-pathname
vs_aix_clus       /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun
filename adapter protocol size mode
hdisk1    fcs0    FCP     15g  C
7.0 和 6.1
controller(7mode)/
device host lun
列出连接到主机的所有 SVM 目标 LIF WWPN
您可以检索连接到主机的所有SVM目标LIF WWPN的列表。
sanlun lun show -wwpn
8.0
controller(7mode)/
target device host lun
vserver(Cmode)          wwpn            lun-pathname
vs_aix_clus          203300a098ba7afe  /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun
vs_aix_clus          203300a098ba7afe  /vol/gpfs_205p2_207p1_vol_0_9/aix_205p2_207p1_lun
vs_aix_clus          203300a098ba7afe  /vol/gpfs_205p2_207p1_vol_en_0_0/aix_205p2_207p1_lun_en
vs_aix_clus          202f00a098ba7afe  /vol/gpfs_205p2_207p1_vol_en_0_1/aix_205p2_207p1_lun_en
filename     adapter    size  mode
hdisk1       fcs0       15g    C
hdisk10      fcs0       15g    C
hdisk11      fcs0       15g    C
hdisk12      fcs0       15g    C
7.0 和 6.1
controller(7mode)/
hdisk1       fcs0       15g    C
hdisk10      fcs0       15g    C
hdisk11      fcs0       15g    C
hdisk12      fcs0       15g    C
